longo »
https://forums.nicoclub.com/longo-u55138.html
Sat Apr 07, 2007 4:58 pm
Ultra, 03' HOnda Odyssey, 92' ford F150elnora Ab.1-24-2007
« Re: Re: (OKVersa) 7:04 PM 4/7/2007
Wierd MPG's are not unusual in the Versa. The gas tank is very difficult to re-fill, it gurgles and gulps, gasps and burps near the top with the hose clicking off each time, and just when all that is all over with, it will still take another gallon.
When I am obsessivly determined to do an accurate MPG test (like every time) I fill it up until the gas actually runs out..(I use a very slow touch on the nozzle to keep the gas from gushing all over me and all the other concerned environmentalists at the pumps. Must be some odd kink in the filler pipe that creates air locks in the route to the tank.
If you do a fill up to the top, drive for only a 100 miles or so, then the next top up has to be up at the same level...not easy to do unless you use the fill it up til' it pukes system. Missing only one gallon on short top ups will give freakishly high MPG's
A recent example, on the trip from a fill up at Flagstaff AZ to Lake Powell UT 127.2 miles on the speedo re set, our 'top up' was 2.04 gallons. It was a reasonably flat stretch, 65 mph posted speed limit and for the first time in 2000 miles of cross country driving, we finally had a tail wind...
but 62.35 mpg!!!?
