I think he reason people are disappointed in their mileage is twofold:
1. Nissan is advertising 36 MPG and over 400 miles per tank. These numbers are based on the EPA highway estimate.2. Many, if not most, people are buying this class of car specifically for its gas mileage.
When you take the combination of these two factors purchasers are bound to be disappointed because the EPA estimate is based on a highway cycle that maxes out at 55 MPH and averages 48 MPH (
http://www.fueleconomy.gov/feg/fe_test_schedules.shtml). That is not realistic with speed limits typically 70 MPH, and traffic usually flowing at 75 - 80. Unfortunately, changing the EPA cycle will be difficult, if not impossible. It is used to determine the Corporate Average Fuel Economy (CAFE
http://en.wikipedia.org/wiki/C...onomy). Manufacturers have to achieve a CAFE of 27.5 MPG or else they can be fined substantially for every car they sell. With that kind of money riding on it there is no way they can change the EPA cycle.
What is really incredible is that the EPA test is so out of whack that the highway number which is indicated is already 22% below what the testing indicates. At the bottom of this page (
http://www.fueleconomy.gov/feg/how_tested.shtml) is this: In the 1980s, an EPA study found that drivers were typically achieving lower fuel economy than predicted by EPA laboratory tests. As a result, EPA required the laboratory-derived city and highway MPG estimates posted on the labels of new vehicles to be adjusted downward by 10 percent for city estimates and by 22 percent for highway estimates to better reflect the MPG real-world drivers can expect.
In other words the test is so unrealistic that the numbers are fudged to try and lower expectations, but they are not fudged enough. Even in the 1980s when the national speed limit was 55 MPH the EPA numbers were unrealistic. With speed limits now substantially higher the EPA numbers are even worse as the basis of determining real world mileage.
Simple physics tells us that a test which averages 48 MPH is going to produce a gas mileage number that is substantially higher than real world driving in the 70 MPH range. Aerodynamic drag increases as the square of the speed. If at 48 MPH you have a drag of X, then at 70 MPH you are going to have a drag of 2.1X. In other words the drag more than doubles. While aerodynamic drag is not the only component that contributes to lower gas mileage, at higher speeds it is the major component. When you double the drag your mileage is going to go down substantially.
The problem here is that Nissan is using the EPA highway number in their advertising and setting unrealistic expectations. I don't see other manufactuers pushing the EPA highway number. If they had used the EPA city number of 30 MPG I think there would be substantially fewer disappointed people on this forum. However, I expect that if they advertised 30 MPG, then many of the people on this forum probably would not have bought the vehicle.
I am getting in the 27 - 28 MPG range consistently on a 50-50 mix of highway and city driving. Instead of looking at the EPA numbers as a basis of comparison, I use my other vehicles. I have an F-150 and an Expedition that each get 13.5 MPG consistently under the same driving conditions for which I use the Versa. On that basis I am doubling my gas mileage, which is fine with me.
