phoenixsuns12345 wrote:I was thinking of getting this HID fog lights 4300K,H11 bulbshttp://
www.hidxenonlights.com/...p-195but this one uses 35W..in the owner's manual (p8-26), looks like they recommend 55W... does that mean that 35w won't be compatible with the electrical/wiring set up already in my rogue, OR could I still have this one installed? if I use the 35 W HID, would it have any electrical problem? thanks
How about Xenon? 55W 4300K. I know when speaking of higher voltage light sources Xenon is whiter (and thus appear brighter) than Halogen bulbs... although I'm not sure this is the case with 12V systems. I also believe Xenons run cooler than Halogen but not sure what benefit that would yield.
Anyway... this eBay seller shows these in a Rogue... but for all I know its Photoshopped.
http://cgi.ebay.com/ebaymotors...ories
Although advertised for the Rogue they don't appear to be custom aftermarket replacements because one of the photos shows something that looks like a under-mount bracket. Then again in the FAQ second they state:
"These lights are meant to mount behind the factory pre-cut fog light holes from the inside of your bumper."
So... my guess is you position them to "aim" out the existing fog light openings in the bumper... but probably not a good option for people looking to upgrade their existing fog lights unless they want to try and modify the housing.
FYI: They also claim they will include a "Free" 7-Color Halo Ring... just for asking.
Modified by Elton Noway at 12:47 PM 7/25/2009
