IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Thu Oct 30, 2003 6:39 pm
the rb25det R33 transmission uses the same internals as the Z32 tt transmission, just different bellhousings to fit the rb, and the output shaft [yoke to driveshaft] im pretty sure is different also.
i was thinking about having a bellhousing made to fit a tremec T56 to the rb26 so i could have a 6 speed, but the original cost of the project would be higher, the gear ratios arent the best, so id have to swap rears, but the cost of replacing the transmission if i blow it up would be less in the long run because i could replace it with a unit thats in every junkyard in america. would reduce downtime in the event i f it up, but its just something to think about.
