rb26 oil pressure drop at idle when hot
MODIFIED AUTO SPORTS
Car: 98 240sx s14 with rb26
i have a 98 240sx with a rb26 just got it up and running good i has a n1 oil pump in it if i drive normal the car is fine but when i drive it hard and gets hot the oil pressure drops down two almost 0 at idle im running 15w40 oil just wonted to no if anyone noes whats going one with it
obx 80mm turbo
obx main
3"down pipe
46mm westgate
880cc inj
aem ems
tomie 290 11.5 procams
and all the goods
n1 pump
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Do you have an oil restrictor for that turbo? What is your bearing clearance? Also does the n1 oil pump come with a new pressure relief valve?
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
I too would be looking into the pressure relief valve.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
what oil pan/pickup are you using?
I had a very similar issue with my sr20 when the oil strainer broke off the pickup tube. It was fine for normal driving, but if i did a few pulls, especially if i was cornering, it would lose pressure when it dropped back down to idle.
