rb26 jun oil pump broke! WHAT THE F!!!!!!!
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
so driving home from a friends place last night and i notice my oil pressure jumping, then my oil pressure light comes on and so i shut it off. i crank it and theres a ticking comming from the lower t belt area (oil pump drive broke) and this all happened on a brand new r33 n1 crank.
any clue if they stand behind their products?????
i know tomei guarantees there pumps to never break..... dose jun do the same?
Sil240
Car: Nissan S13 "The One Cam Wonder"
Did you have a collar on your crank?
julio
Car: RB26 AWD converted S14
Sil240 wrote:Did you have a collar on your crank?
SullivanRacing06 wrote:and this all happened on a brand new r33 n1 crank.
Wow, what kind of driving were you doing to it when it broke?
SullivanRacing06
my low pressure oil light (goes on when oil pressure drops below 20-25psi) came on after i did a 3k 2-3 shift, nothing crazy!
im still takin it easy on my motor bc i just built it.... this pump came off my last 26, maybe it had issues from the last motor?
74260zt
Car: rb26powered early 74 260z car
That crank has a wide flat already on it...
Thats the same pump and crank I'm running. No issues so far...
julio
SullivanRacing06 wrote:my low pressure oil light (goes on when oil pressure drops below 20-25psi) came on after i did a 3k 2-3 shift, nothing crazy!
Yea, that's pretty weird. The only reason I hear of them breaking (any oil pump gear) is either from fatigue or smacking into the rev limiter. You'll have to post up some pics of the pump when you take it apart so we can assess what the mode of failure was.
SullivanRacing06
i was driving normally when i saw the low oil pressure light come on. no were near the red line
towed the car home at 945 last night had motor n transmission out around 1130(our friend captain had us sailing thru the pull quick) planning on puting the engine on the stand and start tearing it down to install the new bearings and tomei pump
while the head is off im having a three way valve job done, installing supertech springs and retainers, new valve seals and 264 hks cams so my head will flow better..
Carl H
perhaps the backing plate bolts on the pump came loose...i always tear apart the pump and loctite the screws back into place.
disrupt
Car: 2006 TRD Tacoma, 1992 240sx coupe
did you have the bottom end balanced? what are you running as a dampener?
toadx8u
Car: 1975 Datsun 710(coming soon F20C)
1993 240sx Vert DD
1995 240sx GT3788 RB25DET
1996 240sx LSx 5.3L
2000 F-250 Crew Cab Diesel
2004 Honda RC51
shoulda had your motor balanced...
FAST-DATSUN
Once you get it apart you will find you should have put on a crank collar. it all looks good until you est everthing and find out only about 1/16 to 1/8 is actuall hitting the rotor of the pump....
Post pic of the broken rotor and we can see the engagment of the collar. also need to check the pick-up and pan for problems.. Many parts are being sold here under wrong info and people sell lack proper knowledge of what there selling.
julio
FAST-DATSUN wrote:Once you get it apart you will find you should have put on a crank collar. it all looks good until you est everthing and find out only about 1/16 to 1/8 is actuall hitting the rotor of the pump....
Come on people, read the post...
SullivaRacing06 wrote:and this all happened on a brand new r33 n1 crank.
SullivanRacing06
i pulled the pistons n rods apart, weighed and balanced them
compared the r33 crank collar to a jun collar and mine was the same size
cross reffd the part number and it came up as a r33
im currently in a argument with jun about the pump
been in orlando / tampa/ miami so i havent had time to pull apart yet
hopefully ill be able to pull it out and apart on monday night.. my girl wants to help so i guess well see how far we get haha, get distracted easily..
SullivanRacing06
im ordering a tomei as soon as glenn gets back to me about the price....... checkin to see if the bearings wer effected, i caught it rite as pressure dropped under 20, if they look ok then ill install another set of std acl race bearings and just be waiting on the tomei to arrive then ill have it back together
also my trannys input shaft bearing has been makin a hell of a noise im thinking that could of caused this entire mess....
vibrations goin thru the crank from the transmission
Sil240
If I were you I would just switch to a OEM pump or get an external pump with a Crank pulley with a Gear drive.
How much does a Tomei pump cost?
Carl H
is the pump actually damaged?
having oil pressure less than 20 psi isnt too far fetched...when the oil in my car is hot it will drop down to as low as 1.2 bar when it normally sits at 1.5 bar.
SullivanRacing06
yea i restarted the car for a second and the pump was making noise.
tomei's retail between 1500-1750 he said he can get me one between 900-1100
SullivanRacing06
Carl H wrote:is the pump actually damaged?
the oil pressure in my 26 has always been 110-120 start up and will drop to around 50 at warm idle (700-750)rpm @ 155deg and with the a/c on 195deg it will drop to 45psi
my oil temps never go above 140while driving and will stay around 160 on auto x tracks
toadx8u
1993 240sx Vert DD
1996 240sx LSx 5.3L
2004 Honda RC51
that pressure sounds really high to me...just saying...its one thing to have a high volume oil pump(good thing) but a high pressure oil pump can mess things up inside the engine if its not designed for it...it sounds like maybe jun coulda sent you the wrong kinda pump...idk just what it sounds like to me....my rb never had over 50 psi for oil pressure like carl said it usually hangs around 20 at idle...
SullivanRacing06
the jun pump relief spring is 120psi so i dont think any thing is wrong there
the pick up and pan had nothing in it
has acl race bearings and a tomei 1.5mm reducer to the head and rotella 15-40, i dont see anything wrong with to much oil pressure............
toadx8u
1993 240sx Vert DD
1996 240sx LSx 5.3L
2004 Honda RC51
why are u running diesel oil in your car with much tighter tolerances?
gawdzilla
Car: none
too much oil pressure is bad. it stresses bearings and the pump. running oil that is too cold is also bad. 140-160 is cold for oil. that's basically like driving on a motor that has not been warmed up yet.
WhatsADSM
Car: 1998 240sx
Throw in another vote for pressure around 20psi at idle on a rb26. 55 at idle sounds CRAZY high.
gawdzilla
Car: none
yep. 20-25 psi range for warm idle
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
+1 for 20 psi @ idle and normal operating temp.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
And exactly what pumps are all these people claiming their psi in the 20's using? Can't really compare a stock/n1 to a 1000 dollar pump that outflows them by leaps and bounds.
His oil pressure may be way higher with a combination of more flow and that thick diesel oil being used. The oil temps seem a bit low while driving though. Is there an oil cooler without a thermostat installed or something?
R32ONP
Car: R32 Skyline GTS-T
RB20DET
the thicker diesel oil would make more pressure and also depending how old the oil is will make more pressure wen the oils old and thick and has crap in it....imho 55 is too high on idle lol..but could be wrong...i get around 1-2 bar hot on idle and 4-5 bar max........pressure isnt everything tho..alota pressure can be bad as it could airate the oil....the oil volume is alot more important than the pressure....
just my 2 cents
julio
gawdzilla wrote:yep. 20-25 psi range for warm idle
+1 with an N1 pump.
toadx8u
1993 240sx Vert DD
1996 240sx LSx 5.3L
2004 Honda RC51
ItzGenX wrote:And exactly what pumps are all these people claiming their psi in the 20's using? Can't really compare a stock/n1 to a 1000 dollar pump that outflows them by leaps and bounds.
flow is one thing...pressure is another...thats why a 5-9psi fuel pump can FLOW just as much as a 40-60 psi pump...often times more cause it doesnt have to achieve the pressure that the high pressure pump does
there are 2 kinds of oil pumps that most companys make...HIGH VOLUME and HIGH PRESSURE....high pressure is designed for a motor thats built LOOSE not tight like the factory specs are...it could be such a thing that jun sent him the wrong kind of pump or he may have ordered the wrong part number not realizing it was high pressure...
im also guessing he built this motor to factory specs therefor it cant handle the pressure that the pump was putting out...the pump was being backed up and over worked and eventually failed...if you tell jun you were running 15-40 they are gonna laugh in your face and tell u to eat it and buy a new pump...the pump is not designed to move oil of that viscosity...
the brand of pump and how much you pay for it has nothing to do with how much pressure it puts out...all the companies know what the factory specs are and they may up the pressure some but what they are going for is more flow...more oil flow means less wear on parts...which leads to longer engine life...now go adding a s*** ton of pressure and it adds stress to places it doesnt need to like the journal bearings and the cam bearings...
so swinging your 1000$ oil pump stick dont amount to a hill of beans...cept that your paid oh about 800$ more for your oil pump than i did and mine hasnt failed yet...
i still attribute most oil pump failures to a lack of engine building know-how...if you are going into the motor to replace parts on the rotating assembly (IE: rods & pistons) then guess what you just f*%ked up the balance the motor had from the factory...no harmonic dampener in to world is gonna help that not even the ross racing products...you need to send the whole rotating assembly (balancer to clutch) to a balance shop where they will weigh each piece and spin balance it with everything else...determine where it needs weight added and weight taken out and then send it back to you after balance has been achieved...it only costs about 300$ and its a great piece of mind...i have been building motors for about 15 yrs now and i have never had a motor fail due to a rotating assembly issue...
sulli good luck with your repair
RANT OVER!!! :dblthumb:
R32ONP
RB20DET
dayyymmm +1 for the knowledge in that post ^^^^^^^^^^^^^ :)
