Sil240 wrote:Look into an accusump.
It's a pressurized canister that holds a quart or two of oil.
I know the difference. Accusumps are great for what they are advertised for. Starting up pressure, maintaining pressure in high g cornering where sometimes it might fall off, and in the event of a failure.
I want a dry sump to eliminate that failure. With the accusump, and a stock/stock style pump, you bang off the limiter or rev it high (7-8-8.5K) and theres always a risk of the gear breaking. The accusump provides pressure and you save your motor, but you still have a broken oil pump and maybe metal in your oil.
The dry sump would never have that problem. And if your that paranoid about it you can wire an ignition cut to a pressure switch. Below 15-20psi? Cuts ignition. But then your good for any rpm you want and it really wont ever break. And oil pooling in the head wont be a problem either.
~Alex
