Yes he is. Larry did all the tuning but Chris (aka Mr. T) did this last pull. Larry was on the other side of the shop with his hands over his ears.FrostyRB wrote:larry is a good guy. very smart. he does a bunch of work on my friends supra.
DBB's and Open Gates FTW.kjlindgr wrote:Yes he is. Larry did all the tuning but Chris (aka Mr. T) did this last pull. Larry was on the other side of the shop with his hands over his ears.
Same one...right below the oil plug in the head.tight240 wrote:Which freeze plug was it? I had mine pop out of my rb20 in the very back of the motor during regular driving.
Ehh, I see what you are saying, but our cast iron blocks are not very ductile....Darius wrote:Not blown. He popped a new one in and runs fine. I think the block flexed enough to pop it out. I'm also imagining this is the reason why people with serious hp RB's have used resin to fill or partially fill the coolant passages in the block.
A lot of drag spec blocks have their cooling passages filled for hardening/strength. Also the reduction of cooling passage area increases the pressure within the cooling system.Darius wrote:Not blown. He popped a new one in and runs fine. I think the block flexed enough to pop it out. I'm also imagining this is the reason why people with serious hp RB's have used resin to fill or partially fill the coolant passages in the block.
EmailedBwana wrote:Shoot me an email and we'll see what I can do for you on a set of L19 studs...
Now that's what I like to hear!kjlindgr wrote:Stronger head studs are a must. I've got a 225 shot of nitrous I've been dying to use too.
...and I'm saying "I wish I could break my headstuds..." funny world. Just makes me want a bigger turbo that much sooner.kjlindgr wrote:I've gotta break something cooler than head studs.
