RB26 38PSI dyno pull
kjlindgr
Here's a quick vid of the FD doing a 38PSI dyno pull. It blew a freeze plug out of the block at the end of the run...hence the smoke. That put an end to the dyno runs for the day so I was kind of upset that no more power was to be made.
http://www.gtchannel.com/content.php?cid=12016
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
Sounds badass!! **** hurts my ears lol. GT42?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
HOLY $HIT!!! Once that thing spooled all hell broke loose! Were you tuning it or was that a WOT run? It seemed to take ages to spool. I can't wait to see a video of that thing on the street/strip.
BTW how does one blow a freeze plug out of the block? Was there some kind of head gasket issue or was it just a freak occurance?
kjlindgr
Yes...for now.
kjlindgr
It's already tuned. We were just doing WOT pulls. Not sure how the freeze plug came out but it did. At first we thought we stretched the head studs since we are using standard ARP2000's, not L19's. After further inspection (and the freeze plug laying on the dyno) we determined that was not the case...yet.
nizmo zilvia
kjlindgr wrote:Yes...for now.
Thought so.
Shocker
Car: 89 240sxHB rb26/30
One of my favorite swapped RB's ever right there......and the power laid down?
nizmo zilvia
Shocker wrote:One of my favorite swapped RB's ever right there......and the power laid down?
Not enough for him to share with us
jk
240wootie
Car: 1989 rb20 coupe, 2002 WRX
simply beautiful... sound, sight.. ahhh... i watched it 4 times..
gawdzilla
Car: none
damn... hope the block isn't messed up. freeze plugs don't just fall out for no reason
nizmo zilvia
True but dont they pop out to prevent your motor from being heavily damaged? If I remember when I took shop back in the days in high school my instructor told us that these are cheaper to fix then for a motor to just blow.
Carl H
they are there incase you were stupid and used water instead of a 50/50 mix...hence the name freeze plugs.
nizmo zilvia
lol
kjlindgr
I'm not sure why it fell out either. The coolant jackets probably only have about 24-25PSI max in them so it was weird.
240z4u
Car: '95 Nissan 240SX
I have a close friend with a nissan L28 turbo that likes to blow out freeze plugs on occasion. He still doesn't know why, so please post up if you figure it out!
Hopefully it does not happen again.
Evan
Darius
Could the block be flexing enough to pop them out? I'm fishing here.
kjlindgr
Really not sure why it came out but I'm half thinking about tack welding the next one in.
bumblebtuna
Car: rb25/26 2fotay
kjlindgr wrote:Here's a quick vid of the FD doing a 38PSI dyno pull.
damn f16 fighter jet engine, lol damn
300Plus
Car: 1995 S14 w/ Rb25det Series II
hmmm I would think the only way the plug would fall out would have to be extra pressure in the coolant passages = lifted HG or maybe extreme blow by plus other problems?? one thing is for sure they just dont fall out unless they are old and rusted apart.
nice vid though. keep us updated on the car and the freeze plug
gawdzilla
Car: none
extreme blowby wouldn't reach the coolant..
my guess is the HG lifted causing the coolant to be pressurized... don't think the block can warp up by where the freeze plugs are either. hopefully its just some random occurrence? hope its nothing too serious.
i'm curious to know what caused this... have you leaked the motor down or compression tested since it happened?
300Plus
gawdzilla wrote:extreme blowby wouldn't reach the coolant..
yea I agree thats why I said plus other problems. Could be intake mani gasket, might have pushed a little extra psi into the coolant chambers, I've always hated the design of the intake mani for that reason
meet07
Car: 89 180sx rb25det
when the freeze plug blew out of my plymoth laser it was due to a headgasket going bad. I agree 100% bad HG
BoostFab
Car: S13cp, S13fb, S14z
awesome; woow just woow; i luv the fd
corey_m_brock(BANNED)
Car: s13 coupe w rb25det gt3582
kjlindgr wrote:Here's a quick vid of the FD doing a 38PSI dyno pull. It blew a freeze plug out of the block at the end of the run...hence the smoke. That put an end to the dyno runs for the day so I was kind of upset that no more power was to be made.
so how much power did you make? before the incident
S14eva1
Car: S14 aka "The black bandit"
+1 for excessive pressure in the coolant system......
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
well there had to be somthing that went bad to allow 38psi to get in the coolant passages, so a simple test you can do is do a block test with the dye and it will be able to tell you if it is a blown head gasket or not. also what intake mani gaskets did you use? oem or tomei etc. cause i use tomei intake and exhaust gaskets on my rb26. keep us updated
SeanC
Car: 1993 240sx SE
bad *** video! car sounds wicked once the turbo spooled! what are you revving to. and freeze plugs are wrongly named, they are not meant to "pop" out when the coolant freezes they are merely casting plugs from when the block was cast.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
looks, sounds, etc...awesome.
Please keep us updated on the findings on the freeze plug issue.
FrostyRB
Car: cars, bikes, atv's
did you have the car tunned by SP, & are you using one of their turbos?
kjlindgr
FrostyRB wrote:did you have the car tunned by SP, & are you using one of their turbos?
Yes, the car was tuned by SP. No, I'm using a standard Garrett GT4202.
