RB25DET RB20DET RB26DETT fan and radiator setup
s14_sport
First setup was TOO COLD (Didn't go above 70C!):
Stock Clutch FanCustom Griffin Radiator UNDER rad supportGreddy Coolant BreatherNismo T-StatZ32TT Rad Cap70:30 Mix Coolant
I changed the Nismo T-Stat to a standad Z32TT T-Stat and now I'm constantly at 80C. Maybe a few HARD pulls and I'm at 83C MAX.
Fibre guy
Car: 91' s13 RB25DET, 95' s14 bone stock, 87' Wrangler 4.6L stroker
This thread has been buried for 4 months but I forgot to update it and another thread reminded me of it. I changed my setup again and went for a custom radiator mount with dual I30 fans.With this setup I have 5" from rad to crank pulley without the fans on.I need to re-do the the hood catch, it sticks when I got to pop the hood.Also, believe it or not, its lighter and stronger than the metal I cut off.
johnny butt
Car: 1993 240sx Convertible
Darius wrote:- RB25- 3-inch thick Griffin drift spec radiator core <IMG NAME="icon" SRC="http://images.nicoclub.com/forums/image ... s/rice.gif" BORDER="0"> - OEM Z32 thermostat (83-84*C)- 2x 12" SPAL pusher fans mounted to the condenser (<----THE KEY )- Soon to have AC (waiting on custom fittings now)- DiF dual fan controller also wired to turn on with AC to keep air flowing past the condenser when stopped or in traffic.- Huge, thick FMIC with stock engine bay undertray. No additional ducting.
Since the SPAL fans were installed, the engine has never gotten above 86*C.
I had some cheap Perma-cool fans installed before the SPALs and they couldn't keep the temps down when the weather was hotter than 85*F outside. Sucked!
Hm, I have a 12" Puller mounted on the passenger side by the coolant inlet & outlet, but I also have 2 12" FAL fans just chilling in a box in my garage that I guess I will mount on the other side of my AC condenser...Some might call it overkill, but I'd rather be safe than sorry, you know.
Glad to see someone else is running that setup before I did it though.
Would you mind taking and pictures? or wait, you have an S14, don't you?
Modified by johnny butt at 3:24 PM 9/7/2009
Fibre guy
Just updating on my fan setup.I tried to make it a effective as possible. 5" from radiator to crank pulley. The fans also make a vacuum strong enough to pull my hand onto the intercooler from 4" away when it's on LOW speed. Same go's for my front mounted 10x12 B&M oil cooler.Also, it's VERY QUIET.Link to pics:zerothread?id=453880
rael
Car: s14
OC-KILAFONIA RB25 S2 S14 CX RACING RADIATORSAMCO HOSESDUAL ELECTRIC FANS PUSHERS ON FULL BLAST ALL DA TIME FOR NOWNISMO TERMOSTATSTOCK WATER PUMPWATER WETTER & DISTELL WATER ONLYAPEXI WATER TEMP GAGEGREDY FMIC NO OIL COOLER YET, WORKING ON IT NO DUCTING YETPLANING ON GETTING A FAN CONTROLERTEMP IS 70C ALL THE TIME JUST @ IDLE OR TRAFFIC. 78-80 IN DA FREEWAY MOST OF THE YEAR. EXEPT SUMMER HOT DAYS 72 IN TRAFIC, 84-86 PUSHIG HARD IN FREEWAY.
Nesquick
Car: Rb26 Kouki Silvia
RB262x 12" Flex-a-lite puller fansstock rad.
runs as cool as The Fonz
rbs14kouki
Car: rb27det s14 / sr20det s14
koyo rad ??? how thick is it ... i have a greddy 3inch rad ...
i cant run push type anymore , i need to put pull type on my car !!!
so what rad and fan set-up should i used !!! will a flexalite or fal will fit with my Greddy ?
here is a pic of my set-up
flatrate
Car: S14 kouki
PS steering pump will get in the way of any puller on that side.. thats a sweet intercooler setup BTW
I used a puller on the pssenger side and a pusher on the driver side i still have AC and a front mount but its been cold out so not sure what summer will bring
rbs14kouki
my set-up is a Powered by max high mount intercooler !!!
all my acc are from a rb25 (PS pump , balancer , alt)
the balancer is the one that is closer to the rad ...
Cjmartz2k
Car: Hunting for a '89 GTR now
For what it's worth, you guys know I recently swapped out the mods you see in my build thread (mainly a 4" thick FMIC) for a stock RB25 with stock SMIC, but the same radiator, T-stat (actually a normal temp one instead of the low temp one), WP, etc. I instantly had zero cooling issues. I'm pretty sure it was due to the air flow difference of the FMIC not being there.
rbs14kouki
i had a GTR Greddy type-R 4row before ... no problem what so ever ... but i had i little accident on the track ... and i want to switch my set-up and put my intercooler away from the crash zone !!! and it was way to big for my power goal ... lagy as s***
Neejay
Cjmartz2k wrote:For what it's worth, you guys know I recently swapped out the mods you see in my build thread (mainly a 4" thick FMIC) for a stock RB25 with stock SMIC, but the same radiator, T-stat (actually a normal temp one instead of the low temp one), WP, etc. I instantly had zero cooling issues. I'm pretty sure it was due to the air flow difference of the FMIC not being there.
I'm pretty sure that's what my problem is/was. I didn't have any problems prior to installing my FMIC.
ka24eracer
Car: 180sx...
rbs14 , I will probably run the same intercooler setup and I thought about moving the rad forward by cutting the rad support . Is there any room to move the intercooler against the latch support ?
rbs14kouki
right now it's against the latch support !!! i would cut that lacth suport and run hood pins but it's not street legal to run without the stock hood latch here in QC
rbs14kouki
couls you tell me what is the size is a Koyo or mishimoto !!! i need to star looking for my new set-up
koyo with flexalite or FAL ??? what do you guys think ?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
I say go for stock fan clutch. My car idles at 169 deg.
SIL-LINE
Car: S-13 With RB20det
CXracing rad Two puller fans on an old flexlite plastic fan shroudfans turn on with a relay connected to ignition signal and an oil cooler on the passenger side next to IC ducted . i also have a Radiator Diversion Cooling Panel.
