How does the Gizzmo install? I take it you attach it to the input side of the ignitor? And you install with all 6 trigger wires right?rb25drag wrote:Well im glad there is Several alternative options out there!! Everyones setup is sweet!! Good job by everyone, Im Really interested in that MSD tho, Im really worried about my Launch Control working. Does anyone have any experience with the Gizzmo launch interface on a different coil setup?
might not even be that complicated, depending if its a quality one or not. i know the cheaper ones like bee-r only have 4 wires i think. 2 inputs from CAS and +, -.WhatsADSM wrote:
If so it will work fine if you use the blaster coils listed above.
As a side note. How much did you pay for that gizzmo launch control? I could probably make those things for people for pretty cheap if there was a demand... shift light and all
The Gizzmo has 16 wires, 6 input on coil signal to ECU and 6 output to coils from gizzmo, 1 ground, 1 power, and 2 tach signals, one from ECU to unit and one from unit to Shift light. Nothing hooks to the CAS.WhatsADSM wrote:
all good. i think that crappy weather is making it's way here now. i'm still struggling with finding the proper fittings for this new setup, so my car isn't going to be anywhere close to needing the coils back this coming weekend.cdorhout wrote:It's been pretty crappy weather here this week, so I don't think he's tried the Split Fires yet. Have you Matt?
meet07 wrote:wouldnt it suc if ya found out that the splitfires are the same as the oem's just colored red......
