Why would it? It's a brand new cylinder, of very similar proportions...s14kouki wrote:lets just hope it doesnt blow out in a week
Dual Diaphram!! good lord. I had one of those on my SE-R sentra way back in the day. I killed 2 oem clutch cables with that Pplate lol.Taffy wrote:I have run just about every clutch and slave cylinder combo on my RB25. I tried OEM Nissan, Kragen, and Nismo. The ones from the big parts stores are Chinese parts. They last for a little while, but if you are going to run a heavy pressure plate, they will break. If you don't mind changing out the slave cylinder on a regular basis, the Chinese ones work.
If you have the money, the Nismo one is well worth it. I ran the Nismo slave cylinder with a dual diaphragm heavy duty pressure plate, and it never gave me any problems, plus the pedal feel is better with the Nismo. They are pricey though....
I have the 25 and ordered one also. It seems correct. The only thing I have to change is the line itself. The original line the threads are too long on mine.DriftingisLame wrote:Sorry to bring this thread back, but I just purchased that Napa part 37487. Not even close, there are mounting holes on the bottom of the cylinder, instead of the RB's one on top and one on bottom of the cylinder.
Did they screw up my order? Can you confirm that the part number is correct?
Thanks-Max
i used the KA's on the old rb20 i had. i saw it's look the same, so i just unbolt it from the transmission , then lleft it hanging with the line connected, not having to bleed it afterwards. lol.DriftingisLame wrote:Damnit, I messed up. It seems that part number is for the rb25. I missunderstood.
Carl the KA one works? NA/TT Z32?
