>>>> RB25DET 240SX SWAP QUESTIONS<<<<
skywise
Alright so i have a 91 240sx with a knocking motor. I want to do a rb25det swap into it but im not quite sure how much everythign is going to cost. right now i can buy a rb25 with transmission,ecu,wire harness,cross member,maf sensor,turbo,coil pack,alternator,starter,a/c compressor,power steering pump, intake manifold,exhaust manifold,clutch,flywheel,pressure plate,and throttle body for 2,200. Than i would have to go to mckinney motor sports to get the motor mounts and drive shaft and timing belt. that is going to cost me about 1300.
Now can anyone tell me what else im going to be needing to complete the swap and how much it would cost to do the full swap.
and also i have heard that if you just put the same amount of money into the ka you could get much more hp then the rb stock. can someone please get back to me with this.
QuickerThanU
Car: 98,95,94,89 Nissan 240sx
You're prolly lookin to spend about $25,000usd for entire swap. nah j/k my s14 rb25 is close to cpmpletion. I have all the parts includin fmi, wiring and greddy intake mani and the needed maintanance parts like belts and water pump. I just need mount kit and r33 xmember. All in all including labor to put it in and all parts needed, i spent a lil less than 6k.
boomers04
Car: none
they make a front end clip at JDM-onlince.com shipped to your door with eveything included need to do the swap xmember axles, drivetrain, turbo, fmic and piping, fuel rail, ecu transmission, wiring harness, everything 4grand
skywise
will that come with everything needed to fit into my exact model of 240
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Joe
searching and reading stickies are your friend!
