chad b. »
https://forums.nicoclub.com/chad-b-u120574.html
Thu Mar 06, 2014 4:44 pm
I will tell you what I would do, and you can take it for what it is:
I would def. buy a good fpr. An Aeromotive or a Fuel Lab. I personally wouldn't trust a stock fpr running twice the fuel pump to it. I don't think the stock coils will give you any problems. I made 500whp @ 21psi with sock coils with no misfires or blow outs. I did, however, replace them with SplitFires because it allows you to open up the gap on your plugs for better idle. Yes, you can buy LSx coils. What they aren't telling you is the wiring involved and making a bracket/mounting/etc. Yea, the SplitFires cost more, but they are made for your specific engine, direct replacement, and have an excellent track record. Not saying they work better, but they are easier, and look 1000x better in the bay vs a homemade bracket with plug wires. As for the MAF/MAP question: the AEM is made to run a MAP sensor with the help of an IAT. You will need both. The z32 MAF (N62) can monitor enough air to make more power than that turbo you bought could ever produce. You can even get them in aluminum housings for a blow through setup. Just always consider your surroundings. How many tuners close to you not only know the AEM software very well, but are also very knowledgable of the RB and what it wants and needs to start, idle, drive, and make good power? I had a 30-6620 on my car and sold it for an Enthalpy setup. I personally think an AEM standalone is not made for street cars. They're way too complicated and involved. Plus they will not simulate or read narrow band O2. That being said, your car will never start, idle, or drive as good as it would if it were running a stock mapped ecu. This is my opinion based on personal experience. Take it for what it's worth.
