cvc9216: thanks for the info, I assumed the oil return was 3/4" BSP but just wanted to confirm.
Boostfed is right....I don't want any banjo fittings at all. I want to use all AN fittings with Earl swivel seals and hoses. This is why I am looking for these adapters.
Anyways.....this is what I found....
oil return: 3/4" BSP to -10AN adapter at available at
http://www.batinc.net, can't find anyone else that sells this. here's a direct link to the pdf file from their site:
http://64.202.180.37/files/un816.pdf (second page, first item)
oil feed: M12 x 1.25 to -6AN adapter, Earl makes this fitting (part# 991945). You may not want to run -6AN because thats pretty big for an oil feed line, so you can get Earl's -6AN to -4AN reducer (part# 989464) and run -4AN lines.
coolant return: M14 x 1.50 to -8AN (part# 9919EFH)M14 x 1.50 to -6AN (part# 9919DFH)M14 x 1.50 to -4AN (part# 9919BFH)Just choose the one you want based on the hose size that you want to run. However, I will be running an aftermarkey turbo so I am looking to plug up this port in the block. So I plan to get the M14x1.50 to -4AN adatper and then get a -4AN cap.
Hopefully this will help someone else out. If I made any mistakes, please let me know so I can correct it.
