RRRRB wrote:Is that a big deal with that pump?
which pump are you running and what base fuel pressure are you set at?
Im thinking about making my fuel setup simpler, im using twin bosch 044's in a surge tank with a intank walbro feeding the surge tank.
i need enough pump for 800whp on E85 and have to run a 55psi base to make my injectors flow enough as well..
Yes, pumps do not do well with restrictive suction or a suction lift where it has to draw liquid up to a higher elevation before getting to the pump. But once at the pump, it can "push" 10X better. Another problem with a restrictive suction line is it can cause the fluid to cavitate or "boil" ahead of the pump. Once that gas pocket hits the impeller, it turns back into a liquid rapidly. This violent transition will eventually destroy any pump from a little fuel pump to a massive industrial pump.
A good rule of thumb is that you want to keep the velocity in the tubing less than 10 ft/second. Fuel has roughly the same viscosity as water, so you can use basic hydraulic calculations to calculate losses. I realize this is more engineering than hobby talk, but velocity (V) is flow (Q) divided by cross-sectional area (A) of the tubing. V=Q/A
That fuel setup is tried and true, so it shouldn't be an issue. You'll have to look at how much fuel you need to make that power and what psi of boost you will be running. So say you need 8900 cc/min to make 850hp at the crank and 35 psi. If your base fuel pressure is 55 psi, the pumps need to be able to deliver the fuel at 55+35 = 90 psi to overcome the intake pressure. So, the design point is 8900 cc/min=8.9 L/min=534 lph at 90 psi. Running two pumps in parallel cuts the flow in half, so 267 lph at 90 psi per pump. If the pump can't deliver that pressure, you need a different pump with higher pressure rating. I didn't want to rely on two fuel pumps so I went with a single 41402 Fuelab pump. Pumps have drastically improved over the past 5 years so I'd look at in-tank options if they can meet your needs. That way you don't have to change up plumbing as much.
