this is just stupid, do not take this into consideration..why?coreansurfer wrote:assuming you can get motor + transmission for free
assume 400-500 for driveshaft800-1000 for mounts600-1000 for intercooler2000-2500 for install
youll be hurting either way.
because...
275 shipped steel driveshaft399 shipped aluminum ...from thedriveshaftshop (custom even cheaper670 shipped syko mounts + jhot sells x/members $70 375 shipped gtspec intercooler kitinstall...eh, depends.. where most of us save the money
....grand total.....1700 give or take...
what about wiring? a good clutch? replacement parts.. IE: water pump, timing belt, idler/tensioner. New radiator, dual E fans. How about an LSD to get the power to the ground. What about brakes, so you can stop after you hit 100mph in only a few seconds? Whose got a FPR? Walbro 255 at least?bumblebtuna wrote:
because...
the answer is no and no. the rb25 would be somewhat "cheaper" because you would only have to replace one turbo versus the two (unless you do the big single, which you can't afford) on the 26, and you probably wouldn't need to buy the 25 transmission seperately ($1300). also the 25 pan doesn't need modification. other than that they have a pretty similar list of crap that needs done.kevinarich wrote:I plan on a front mount and a new turbo and all that jazz, is the 26 any cheaper to get running? Or is it considered a 10000 swap because of the price of the engine?
Oh cooooll!!!11 that is the exact same thing as a "budget" RB build.S12_hybrid wrote:Just as proof that "HIGH COST" builds can be done for cheap... http://www.northwestnissans.co...18224
No need to be jealous because I built something for less by sitting and thinking about it first. Ah yes thinking, you must have trouble in that department.bone_stock_240 wrote:
Canadians .... ....
Oh yeah, I lack in the thinking department. I am sure you know all about thatS12-hybrid wrote:take it back to grassroots, and get your heads out of your A$$E$.
intercooler is best bang for the buck, Hybrid GtSpec Intercoolers are NOT ebay intercoolers. aussies speak very highly about them...coreansurfer wrote: wow, 399 sounds mighty close to 400 dollars
as for the mounts, my bad i got the mckinney set when it first came out, cost me about 950 shipped
as for your hong kong 375 dollar intercooler, no thanks.
and if someone is asking this kind of question, do you really think they can do the install themself?
i was just replying to his list of misinformed info... no saying RB's aren't money pits...just saying you can save a little by looking around.Shocker wrote:
How about left over money for **** that might not go right.....
I couldn't agree more. People purchase items which will "support" X amount of horsepower. ie: 3" IC piping, 3" exhaust, An intercooler the size of a soccer field, a 90mm throttle body (Some need it to fit their intake manifolds), a "high flow" z32 fuel filter [psssst, it just holds more fuel], a clutch to support 900 ft/lbs and then leave it at BPU power levels...bumblebtuna wrote:
just for you... http://hiprollc.com/Merchant2/merchant.mvc enter "FMIC50" at checkout to save 50 bucks... 375 shipped!
.bone_stock_240 wrote:edit: And what exactly am I jealous of? a pieced together mish mosh of an engine build in a 20 year old s chassis? Damn dude, you are right. I am mighty jealous.
