Eikon »
https://forums.nicoclub.com/eikon-u15727.html
Thu Jan 06, 2005 10:44 am
WOW!!! All kinds of crazy ideas flying around in this thread.
Here's what I know...
You don't have to have McKinney or any other mounts to put an RB20 in your car. The R32 stock crossmember will do the trick just fine.
The RB20 doesn't change the balance over the front wheels... it sticks out a little further in the front, and also a little further in the back, so while the total weight of the front of the car is slightly higher, it doesn't ruin the balance over the front wheels as someone previously stated.
The SR has more torque? I don't think so... I think the RB20 puts down 185 ft/lbs. I'm not sure about the SR as I have not seen a dyno comparison, but I would think a 6 would outdo a 4 in torque? Not that number of cylanders is the factor... it just usually happens that way.
I don't know of any SR's that you can get locally.. unless you are talking about front wheel drive SR20de's from Sentras and SE-R's.
Why are we talking about the RB25? The thread was to compare RB20 to SR20.
I can't talk to much about the SR20, but I can tell you about the RB20.
RB20's have poor cooling systems. If you get one, you would be wise to replace the radiator for an upgraded one, replace the water pump and thermostat, and also the heater core just to be safe.
RB20's have a pretty weak Turbo stock. They run out of breath at about 275hp. Upgrade to a t3/t04e and you can push 400 hp with other supporting mods.
RB engines sound amazing!!!
You can get an RB20 clip to your house for under $2k. You don't need mounts, you don't need a custom driveshaft. There is enough info out there on this forum to get you through the wiring yourself. You can do some pretty simple upgrades (fuel pump, radiator, fuel filter, power steering lines, etc...) You can easily have it in your car and running awesome for $2500.
From what I've seen SR20's cost like $2200 for the clip and then figure another 6 to 800 for shipping.
Parts aren't too hard. Most parts are available here in the US market. Some parts are specialized, and places like DDX, Phase2motortrend, RBmotoring, and others in the US carry them.
Some items are rare and hard to find.. but you can get in contact with American's in Japan, or Aussies or Kiwi's and they can help you find them. It isn't often you have that problem. The only part I have had trouble with so far is the ECU engine coolant temp sensor, and I wound up getting that for $20 shipped in 2 weeks time.
In the end do what you want. If you like SR, go SR.. you will love it. If you want RB, go RB! You can't loose on the deal. Both are awesome!!!
