RB20DET --> USA interchangeable parts
dohctor_yaj
Car: cars!
which parts from our US cars interchange with the rb20det? I know Night has some stuff on the rb25det but what about the rb20det?
oil filters? spark plugs?
does anyone know which oil is best? does it need to be synthetic?
which motor oil to use for the transmission? 10w-40?
dohctor_yaj
Car: cars!
from what I've heard of:
the sr20det and maxima clutch kits should work with the rb20det...
anything else?
veilsideS14
I know the oil filter on a KA24DE and RB block are the same.
dohctor_yaj
Car: cars!
I've also heard unstable comments about the ka and sr short shifters being compatable with the rb20det...anyone have confirmations on this?
d240t2
I have confirmation on it. The shifters are interchangeable. The transmission internals are the same...cases are different.
Dennis
WDRacing
300ZX spark plugs and coil packs are the same. On a turbo motor you want to use a full synthetic. Somthing heavier like 5-50 or 15-50, it will help prevent your turbin from coking. I would use redline oils if I was in the states. If not then I use Mobil 1 15w50.
WD
ZERO
Car: AE86 GTS Liftback
Dennis:
When you say that the transmission internals are the same. Do you mean the rb20 transmission's internals are the same as the sr20 AND the ka?or just one of them?
This is probably why rbsileighty didn't have to change his driveshaft.
Projekt
no what he means is that the transmission is basicall the same, ie you can take out the gear set from one and put it into the other. the bellhousing pattern is different. the reason you change or don't change the driveshaft is the length
correct me if i'm wrong.
dohctor_yaj
Car: cars!
WDRacing, the 3Z stuff, is that compatable with the rb20 also because night said its compatable with the rb25 but are you pretty sure its also compatable with the rb20? just want to make sure bro...
anyone have info on oil filter for rb20?
what do you guys think about Valvoline 15-50 racing formula synthetic blend?
I'm still skeptible about rbsileighty's striaght drive shaft swap...i'm not doggin him, since he did do it already, but other people said that it wouldn't work...i guess i'll have to see it for myself this summer...
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
Just FYI... the speedo out of the KA (electric) will swap out directly with the one out of the RB trans. I tried it when I got home and it works. I am in Charleston SC now so I have been away from the comp for a while (don't have internet access yet... at a friends now). They job at Bosch rocks by the way!
WDRacing
dohctor_yaj wrote:WDRacing, the 3Z stuff, is that compatable with the rb20 also because night said its compatable with the rb25 but are you pretty sure its also compatable with the rb20? just want to make sure bro...
Most of the RB25 parts will swap over to the RB20.
dohctor_yaj
Car: cars!
thank you WDRacing...
one question about injectors...i knoe the series 5 RX7 injectors should bolt right in...part number: Denso 195500-2020
those are the 550cc injectors...now the question is shouldn't i be able to use the 440 non turbo injectors too?
86-87 13B NT low square center, 460cc, red top, part # 195500-1350
http://cgi.ebay.com/ebaymotors...33554
like i've said before, since my goal is not gonna be over 400hp, shouldn't 440's be sufficient?
I heard it was a rule of thumb for 6 cylinders that the cc's of the injectors will give you the max fly hp out from the injectors...anyone ever thought of using the 440's or do you think that is way too low to be running 350 to 400hp and I shouldn't have even thought of it in the first place?
Projekt
yes 440s would be ok, but that's pushing the limits of them. you also mention S5 injectors, but the S5 was 89-91
edit: those are top feed, i thought the 20 and 25 were side feed.
dohctor_yaj
Car: cars!
nope...only the rb25 is side feed...the rb20 is top feed high impedence...which is exactly the same as the 89-90 ka24e's...
I'd just thought shiet, if i only want 400hp, i think 440's should be good enough be daym, 440's are cheap as hell on ebay... i can probably get a set of used 6 of them for under a hundred...
vududoc
Car: drag drift autox
RB20 uses the KA driveline straight up and you can swap dust covers. 15-50 should be kool.......as for syn vs standard id be careful on straight syn due to seal shrinkage. alot of the info is on megalla.com and rb20det.net for the parts. Knight also did all the parts swapping too. oil fiter, fuel filter is ka clutch is 300z na. manual transmission fluid is 75-80 or wieghts by tempature but GL4 is i believe what is recommended. My qeustion would be could i swap the mechanical speedo of the rb to the electrical unit of the ka?
vududoc
R32-GTSTWater Pump: 21010-21U25Thermostat: 21200-42L05coil Packs: 22433 60u02 mcp-300124Oil Filter Genuine Nissan: 15208-H8911Oil Filter Ryco: Z145AOil Filter Valvoline: R9Oil Capacity: 4.6L with filter (7.5w 30 is recommended)Coolant Capacity: 9LManual Gearbox: 2L (80w 90)P/s Fluid capacity, non-hicas: 1.8LSump washer 11026-01M02Fuel filter 16400-53J10Rear diff oil 1.5LAlternator belt 11720-24U00Cam belt 13028-20P10PAS belt 11950-04U00NGK standard plugs PFR5A-11 1.1mm gapped NGK Iridium plugs T7341T-8 0.8mm gapped Trust-Greddy Iridium plugs IT08 0.8mm gappedBrake pads and discs for r32 gtst are the same as s13 200sxSpeedo drive gearbox end 32702-58S21Air Flow Meter 22680-02U00
dohctor_yaj
Car: cars!
thank you vududoc...
you wouldn't happen to know the K&N oil filter number for the rb20det now wouldn't ya? hehe...well, if you don't, when i got the time at work, i guess i can cross reference it...
hmm....i wonder how much does a nissan oil filter cost? :confused:
kinda brain fried from school at the moment but isn't the 240s equiped with a inline fuel filter or is it in the motor?
how come i can't go to rb20det.net? do you mean rb20det.com?
vududoc
any where from 3-7 bucks. i get a deal through my nissan dealer becuase i by alot of stuff from them. and yeah sorry i goofed up the net and com part of that. Sorry all. the fuel filter is located in the engine bay.
Projekt
just get a Puroil PureOne it filters better than most and it's 5 bucks.
d240t2
Sorry, that is just plain wrong, Cam. There are at least 4 different oil filters at the dealership. The KA one is different from the S13 SR20DET is different from the S14/S15 SR20DET, etc. Sure, there are 50 different engines and only 4 or so filters...but there isn't just one filter for everything.
d240t2
Fram may make a filter for everything, but Nissan does not. The filters are different...some larger, some smaller, some have shorter threads, etc. There are some little differences.
And, lemme get this straight...are you saying that the Fram guide listed the S13, S14, and S15 SR20DETs and listed them as the same as the KA filter?
But you shouldn't be putting Fram filters on any engine you care about anyways. Didn't you guys ever read that minimopar oil filter study? Fram filters are the worst!
Dennis
rbsileighty
vududoc wrote:My qeustion would be could i swap the mechanical speedo of the rb to the electrical unit of the ka?
Yes you can... I did... fits just fine. I haven't had a chance to run it but it does fit.
zed616
night, i'm curious where you found the fram part numbers for the rb25det filters?
apex_7
Car: 240sx
What about the oil filter for the RB20DET. Also, does anyone know where I can find an intake for an RB20DET? Thanks in advance.:)
sk8erguy1501
Car: 90 240sx KA24DE
I hate skyline engines.
Siddhartha
Car: cars computers women martial arts
I hate stupid people.
vududoc
i just used an adapter plate and an open element from my ka and bolted up. yeah its cheap but works. same thing with my short shifter too
apex_7
Car: 240sx
Where did you get the adapter plate?
Sgt. Kong
Car: 1990 240sx SE
I need a powersteering pump... What do I do? Some s*** hole broke mine durring shipping. Come on nico don't let me down! :ohno:
v kush
Car: 90 s13 coupe rb20 pushin 403rwhp
if u have the bracket thats mounts to the block u can mod an ka dual cam pump heres the link on what needs to me changed
http://www.240sxforums.com/forums/rb-en ... -rb25.html
