AL1222 wrote:does the 97 dash fit right or do you have to modify it to make it work...i want to put that dash in my hardbody..i have a sr20det in mine...but great work man!!! let me know about that dash thanks
there are a couple mods, the defrost duct and the two side ducts are different, the steering column mount it different and needs modding, the center support and driver side brace is different, and the lower mount on the left and right sides are different. the ac panel from the old d21 fits back into the 97 dash, all you do is swap the face plates. the instrument panel has to be completely rewired, and you will need a 97 speed sensor because it is electronic not cable.
SO basically if you have a 97 truck that has the complete dash and can get the speed sensor, your good to go. It sounds like a lot but it's really not bad. If you decide to do it, email or pm me and I will email you both IP panel wire diagrams to rewire it.
ANYHOW..... I cut and shortened the driveshaft, it's in and the truck drove out the shop and back in on it's own power for the first time. I just ordered the AFM yesterday. I put the carpet and 79 280zx center console, getting ready to install the 280zx seats. only things left now are the intercooler and radiator and it's ready for the road........well actually for it's first drift comp in 3 more weeks.
Modified by jmd at 11:05 PM 10/10/2008
