shorten what shaft?? drive shaft?? if so, then did you take off the bars under the oilpan to lower the engine and then slide it back further, then replace them?jmd wrote: you will need to shorten the shaft 3"'s.
I can't find the pinouts for a 93 auto hardbody anywhere. Can you please tell me where you found the info or email it to me or something. I have all the info I need for the wiring (RB pinout and my 240 swap guide points out the important RB wiring) but I need to know the trucks info so I can connect those important wires.jmd wrote: the wiring is fairly simple really. do a google search and you can find the rb pinouts and the truck pinouts. but overall it's really not bad.
just to clarify, did you use the RB motor mounts on the truck frame mounts, or did you use the KA mounts from the truck on the truck frame mounts. Is the oil pan hovering over the "bars" or does it fit in behind them on your setup?? (this answer will help me sooooo much in picturing your setup.)jmd wrote:if you install the motor like i did( cut off the frame mounts and relocate) the oil pan and starter fit perfectly.
Thanks for all of your help. These are my main questions that are slowing me down...just situating the motor, figuring out the trucks pinout, and figuring out why I don't seem to have clearance to slide the transmission on back.
Thanks again for helping me!! Your truck should sell EASY!! I know my project is hot around here and it isn't even running yet...
--TJ
