well since it seems that my name was mentioned and i happened to stumble across this thread while looking for something in the tech section i'll add my .02c ...I do indeed do rom tuning but when i tune cars i use customer feedback to refine the tune for the individual, this allows for an accurate 'mail order' tune that suits the setup of the car.Many of my customers have had great success with the tunes i have provided and developed for them making very nice power and retaining stock drivability.One customer posted his results on nico in this thread:
zerothread?id=292324
upon intial dyno he provided af charts and mentioned that it felt like it had a hole at around 5k and sure enough looking at the dyno and based upon what he had said there was a hole in the ignition map which i promptly corrected and shipped out a new chip.last i had heard the new chip was working beautifuly with no issues and the hole issue resolved.
When modifying the ecus I also use the proper tools, this includes full prep of the ecu as well as use of a hakko 880 desoldering iron that ensures that the ecu does not get damaged.Temp controlled soldering iron and quality solder/chips/sockets are used to ensure reliabilty.
Nistune is a great system for tuning but unless you know what you're doing its a very quick way to torch a motor just like any 'standalone' system.It is almost as bad as using an AFC to 'tune' a car as nissan eccs uses 'linked' maps where tweaking the maf signal to lean or enrichen will cause the ignition maps to shift as well...again not a good thing and a quick way to put a hole in a piston.Also i strongly encourage you to NOT do buisness with some one on ebay or who 'claims' to know how to tune and does so for a very cheap price...i have seen several different ecu 'tunes' that customers have sent their ecus to me to look at only to be horrified to find that it was a stock chip with just rev limiter cranked and stupid timing added to the chip or just simply no founded basis with fuel enrichment and reduction of timing or anything you can imagine really.The tunes i send out to people have been either a) developed on my own car or b) done on local customers cars.My personal car is mapped for up to 22psi of boost and runs z32 maf, 720cc injectors, cams, and a gt30r turbo but starts on a dime every time with great streetability.
If you would like more information please email me as that would be the best bet to discuss without cluttering the thread.
