Are you using the stock 240 radiator or the KOYO? I have the KOYO and flex-a-lite puller fans but I don't have room for them both. One of my homies used the stock KA radiator and he only overheated when he drifted. I wanna use them both I just wish I had the room. Oh well. I'll just use the stock KA radiator with the puller fans. The stock radiator has connections for hoses to the transmission anyway. I'm trying to avoid buying a cooler.nukeone wrote:I have an RB in a '92 vert with both A/C and power steering. No problems with auto transmission using stock KA auto ECU; just don't have the power and hold modes. Like someone said above, just trace the wiring for the auto between the two engines... not a big deal. I have a small transmission cooler and run Amsoil racing fluid in the transmission. Have not had any overheating issues yet. I am using one puller fan on the engine side in front of the a/c compressor area and one pusher fan between my front mount and radiator, that is directly in front of the transmission cooler, so maybe that helps.
What year KA auto ECU are you using?nukeone wrote:I have an RB in a '92 vert with both A/C and power steering. No problems with auto transmission using stock KA auto ECU; just don't have the power and hold modes. Like someone said above, just trace the wiring for the auto between the two engines... not a big deal. I have a small transmission cooler and run Amsoil racing fluid in the transmission. Have not had any overheating issues yet. I am using one puller fan on the engine side in front of the a/c compressor area and one pusher fan between my front mount and radiator, that is directly in front of the transmission cooler, so maybe that helps.
