Rb20 wiring: ECU burning
dudelove2
Car: 240sx S14 95
5 days ago, I started my RB20, it ran great, the wiring was 90% finished. today I finished some thing and wanted to start the RB20 to run correctly but when I put key on ignition, a small print wire burnt on the ecu. I disconnect some wire and weld the print wire and try again.. it do the same thing.... so I disconnect the Black/Red ignition wire and and try it. It don't burn but when I connect the black/red ignition wire and put the key to ignition , the print wire on the ecu burn again!!!
I don't know why, I checked all thing and found nothing!! please help me!
uber95
Car: S14
Check here, best I can do.zerothread/244853
dudelove2
Car: 240sx S14 95
I found the trouble! thank again!
darkstar575
Car: s13 hatch
Well...what was the "trouble"? And what did you do to fix it? Thanks!
