RB20 swap, everything needed
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
Item Description
• IMPORTED FROM JAPAN• Make: Nissan Skyline• Engine Code: RB20• Transmission: 5 Speed• Mileage: Approximately 25-35 Thousand Miles• Condition: Best• Included: Complete MotorComplete Head & BlockDistributor, Intake ManifoldExhaust Manifold, AlternatorPower Steering PumpFuel Rail, InjectorsThrottle Body, Turbo, 5 Speed Transmission
what else would be needed to complete a swap into a s13?
I tried searching :-)
Josh
Sil240
Car: Nissan S13 "The One Cam Wonder"
Not to be a D1ckBut... you definetly didn't SEARCHSince all the answers to your questions are in the STICKES
Acecool
The sticky doesnt specify every item needed and was hoping someone could shed some insight.
Josh
Sil240
What about this sticky??
zerothread/185294
Joe
look harder
Carl H
get a mount kit and converted harness, done.
Acecool
Thats all I would need for the rb I just listed?
Awesome, I may do that :-)
Anyone in Charleston SC want to help?
b00stJunkie
Car: 03 evo 8, 93 s13
if it came w/ the cross member then you can use that instead of mounts, its about 10 wires to wire should take about an hour.
Get an rb20 tach
DJButton
Car: 2010 Nissan 240sx
like Carl said, just don't mess everything up when you it in like me, if it ain't broke don't fix it! still waiting on my freakin MAF!
wob
Car: 93 240sx fastback in the works
Not trying to rain on your parade; but before u buy from the source that gave u that discription,I'd ask for some pictures and some compression and leak down results at the least...If they're telling u that ur rb20det includes a distributor I'd be warry...
All u need is the motorset with maf and igniter, a conversion harness if ur not going to wire the motor yourself,a mount kit or xmember,fluids...And if ur me... A gasket kit,oil pump,water pump,timing belt,tensioner,rearsump,idler pulley, clutch,flywheel,headgasket,headstuds,and a fmi...But I'm not nearly done with my build
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
And remember to change your belts including your timing belt before you put the motor in the car.
dRiLstar
listen to wob he knows what hes talking about...
Acecool
I am no longer buying it from the source above in the first post, but from jdm-online who will supply a video of the compression test, firing up and so on :-)
wob
dRiLstar wrote:listen to wob he knows what hes talking about...
Lol thanks man, that's sig matieral
Acecool wrote:I am no longer buying it from the source above in the first post, but from jdm-online who will supply a video of the compression test, firing up and so on :-)
smart move... I don't wanna see u get ripped off..
