scottymizt wrote:hey bluefire have you ever had an rb20? He is looking for first hand exp, if someone hasnt owned both engines then their opinion really doesnt mean anything. Right now the only thing that is holding my rb20 back from making the same or more power than my modded rb25 is the stock rb20 ecu.My truck weighs way more than any 240 probably ever will and even at 13psi on a t3/t4e turbo the truck makes me smile. I did have enough money to get an rb25 for my truck i just chose to go with the rb20. In my personal opinion the rb20 is well worth the money. I still plan to buy an rb26 as well for either my 67 1600 roadster or maybe swap into my 280zx. Then i will have all of em
No, i've never had an RB20. BUT I have installed, built, and driven a few for some customers. I was not impressed.
Also as I mentioned before any motor can be modded to make more power than another motor. That is a simple and obvious fact, which I do not deny. But in order to compare motors you have to compare multiple aspects and have some sort of equalizer.
Let's say we use cost as an equalizer, Can the average backyard mechanic build an RB20 to make as much power as an RB25 using the money he saved from purchasing an RB20? Possible, but not probable. I also emphasize backyard mechanic so no industry hookups on parts or tools and an average level of fabrication skills.
Now let's say you do manage to make as much power as an RB25 for the same amount of money. You maybe able to hit the same HP number, but your HP graph and TQ graph will definitely not match.
Now we bump the power goal to 500hp. So again can the average backyard mechanic build an RB20 to make 500hp with the same amount of money it takes an RB25 to make 500hp? And again i'll admit possible, but HIGHLY improbable. Also as the power level increases, so does the gap in hp and torque graphs. Transmission reliability for the RB20 will also be way down. Any hards shifts at this point will destroy stock RB20 gears.
And finally since I know someone will say it. If you only want 350 to 400hp out of the motor, you picked the wrong engine. As mentioned before, the RB's strongest advantage is its power potential. If you don't intend on pushing your RB to higher hp numbers then you should have gone with an SR20. The whole indestructible iron 6 cylinder advantage goes out the window and actually becomes a disadvantage at that power level because of the weight aspect.
Honestly in the whole cost vs performance, best bang for the buck, category, I personally feel the RB20 ranks low. Aside from the Naturally Aspirated RB idea someone threw out awhile ago, which takes the crown for worst cost vs performance. Also i'm probably just an RB20 hater.
