Rb20/25/26 cams
themadscientist
I was running two exhuast cams in the purplenurple's rb20. Replaced the intake cam with another exhuast cam. The engine was more powerful but you had to run a fast electronic boost controller or there was a flatspot in the boost response. RB20 and 25 are hydrulic tappet GTR is solid, make sure you don't mix up the parts,ex, RB26 cam with RB20 lifter.
GTR Shop
Car: 180sx RB26 T78, Y31 Gloria VIP + HEAPS of GTRs!
More powerfull?? HIGHLY doubt it.. exactly the same spec cam with 5% different in lobe centre angle.. same duration, same lift
Sil240
Car: Nissan S13 "The One Cam Wonder"
Can i put RB26 lifters, springs and cams in a RB20det??
themadscientist
GTR Shop wrote:More powerfull?? HIGHLY doubt it.. exactly the same spec cam with 5% different in lobe centre angle.. same duration, same lift
did you ride in my car, uh no. The car dynoed almost 10hp higher with the set of RB20DET exhuast cams. I got the idea from a hachiroku freind it's a cheapo 4AG trick. I'm not talking about crunching numbers on a chart, this ain't theory I did it. Do I reccomend it, no. I can get a junkyard cam for $5.00 most people on this board cannot. I suggest buying new performance cams if you want performance.
