Who cares about what turbo comes on the RB20 vs. what turbo comes on the RB25. If we are talkin about making power, we are all gonna upgrade the thing anyways...
I agree with the SR20 comment, I honestly REALLY LIKE the sr20 platform, just that it ALSO is alot more pricey than a RB20. Especially once you consider you need a GOOD motorset, that INCLUDES the maf, ignitor, uncut harness, etc. To find all that you will have to pay. The rb also has a few strong points over the sr such as top feed injectors (again), a higher rev limit, a STOCK t3 setup as opposed to the t25 dealy. Plus, I'm sure this applies to many people, I don't want to be like everyone else. Just because noone (especially stateside) has really pushed the Rb20 doesn't mean it can't be done.
Small note on compression:Again, higher compression turbo motors only really help with making boost faster and when I mean faster I mean ever so slightly.... maybe a hundred rpm or 2. HOWEVER the fact that the static compression of the motor is so high means that there is a lot more heat generated in the combustion chamber and you must in general run much richer and run less boost to keep from detonating. Again the lower compression higher boost combo will make more power... This whole high compression turbo setup in general is a U.S. thing, in many countries (european especially) people will actually drop compression ratios when building motors... Ever notice how guys with a first gen 4g63 will run 20+ psi on pump gas.. no alchy. injection, water injection or any of that.... 7.8:1
BTW, and this is definately not saying that the rb20 trans is that great (rb25 is far superior).... BUT has anyone actually broken their manual rb20 trans? What kind of power were they pushing?
