+1 for z31 tensionermidnightsliding wrote:im running a z31 tensioner
My guess is they did away with the slit where teh spring retainer goes, and went with the 'hole' design to eliminate the possibility of the spring popping out of positionCarl H wrote:the one on the left is how the new nissan bearings are supplied...
Here is a great link to the rb tensioners at a non US inflated price. http://www.nismoparts.com/catalog/?section=756 BTW the RB tensioner has the same part number as the Z31 VG30 engines.uber95 wrote:How much did it run you? It's an aftermarket not a genuine Nissan correct?
I agree with you to a point, but you'd really have to be a dumbass to mess the installation of that tensioner up. If You didnt have the spring in the correct place, that pulley wouldnt sit flush up against the block, and you'd really notice something like that...Darius wrote: That slot in the tensioner for the spring makes me nervous about the possibility of improper installation and subsequent engine destruction. I'm glad nissan modified this into a hole instead of a slot.
Buy the OEM nissan lower idler pulley, its much cheaper and readily available.....002-M-P wrote:I just had another question based on this. I went to advance auto today and found a Z31 tensioner for $38...but then I looked up the lower idler pulley for the Z32...$180. I was perplexed. They had a left lower idler and a right lower idler (the right lower was the cheaper of the two). The one that is currently on backorder at nismoparts is only $30. Anybody have any further info on this?
Just go to http://www.czp.us and buy the darn Z32 lower idler pulley already. Who cares if its a clit-hair's diameter in difference. I put these pulleys up side by side and I cant physically see the difference, and besides who really cares if the diameter is off a smidge? The tensioner (which is verified teh same) is what takes the slack out of the belt, and the only thing that would be affected is how fast/slow the idler turns....002-M-P wrote:Just got off the phone with Shay at nismoparts and the idler pullies are still out of stock at least a few more weeks. So something alternate is definately necessary if I don't wan to spend $150 on ebay for the combo. So anything else?
Atta boy002-M-P wrote:Ok ok, I shall pull the trigger today on the Z32 idler...thanks
