StricNyne wrote:doin a lil grave digging but wuts cheapest someone has found idler pulley for cheapest i got was 80 bux for lower z32
I just figured this out the other day, but do not get the lower idler pulley for the Z32. The snout on it is too long and you cannot get the lower timing cover on if you install the Z32 one. Also its diameter is larger, but a decent amount which makes the timing belt a biotch to install.
You might be able to get away with using that one if you can trim a 1/4-1/2 off the snout of the Z32 snout
