obviously the the twin turbo help produce that torque. i drove one that is propane powered that is all motor, on take off from a stop, torque isn't the same as gas powered, but it's not intolerable.rb25drag wrote:All of those facts sound good except the price. Im sure if you Have a Top of the Line shop install the equipment it could cost 2500$ But my install is looking to be around 500-900$.
I seen a twin turbo small block station wagon running off propane at my local drag strip this past year that left the line HARD!! on the back wheels so Im thinking the torque can't be effected alot.
To me it should have better throttle response due to not having the lag of the injectors holding you back. The instant that throttle is cracked you should have power!
Comparing propane to gasoline isn't apples to apples. Propane is a very simple hydrocarbon, especially compared to gasoline. It burns quickly and cleanly but does not contain nearly as much energy molecule to molecule as gasoline. It allows you to run more timing/boost without detonation but does require a comparatively large amount of fuel to do so.rb25drag wrote:He says propane is = to 110 octain of race gas so it should make alot more power over pump gas!
Well im built with forged internals so No worries about blowing anything.Bwana wrote:It's not necessarily better or worse (though that could depend on application) but the engine will definitely need to be purpose built from the bottom up for propane if you want to experience satisfactory results.
i like how you think forged internals means made of magic fairy dust and completely indestructablerb25drag wrote:
Not indestructable but alot safer from breaking parts when experimenting.gawdzilla wrote:i like how you think forged internals means made of magic fairy dust and completely indestructable
Sil240 wrote:So your doing a Carburated (ewwwww) Propane setup??????QUOTE]
This is not a carb injection. They are now making actual throttle bodies. This is going to take the place of the original RB throttle body.
Yes I like being alot different. I never take the same road as anyone else.Sil240 wrote:If your looking to be different, then thats effin cool.
My plan is to get rid of all that B.S, All of that crap cost a stupid amount of money and if it can be deleted its going to be. I like a simple setup, Rb's are made like a woman and I plan on building a man! Simple and to the point.Sil240 wrote:So a Propane carb RB25.......There goes your ECU, and all the sensors, Tbody, injectors, Intake manifold. Or you could make a adapter plate to bolt on a big side draft blow through carb. 6 side draft carbs with a air box/mainfold would be sexy though....Well actually no you ECU can't go away, unless you get a stand alone or some kind of Distributor setup. Or have the ECU chipped to only run Spark. If your motor is built, I think you'd make more power with a regular setup.PFC or Chipped ECU (Cheaper) and bigger injectors.
Actually with Propane you don't have the cold run 2,000RPM to warm up starts and if you decided to store your propane car for lets say 5 years. There is no need to drain all the gas and B.S all you do is close the tank valve. Come back in 5 years crack open the valve start it up and Drive home. Simple nothing to it, To me thats not old school 60's because back in the 60's you had to vacuum secondary carbs that took FOREVER to warm up.Sil240 wrote:But with all of that, it puts you back into the driveability of the 60's. Crappy cold starts, change in pressure, humidity.Plus with the added PITA of the black art of tuning carbs. Especially since most people aren't tuning Propane Carbs.
I personally think if you want Propane, just do add on Propane injection. So after the race you can hook your car up to the grill and make some burgers!!!!!
If you really want torque, go get one of those RD28ET's with Propane injection.
If I loose a little power on the fuel thats ok, Because from the money Im going to save from not having to buy all that ECU crap and injectors ill be able to buy a bigger turbo to make up for the lack of power.
Propane isnt something people are use to and its different. Thats why, mine is soon going to be the 1st that I know of.
