Hey,
I'm running into some trouble with my IC piping.So what I'm thinking about doing is getting one of DJButton's high pressure lines.
Then running one of these universal coolers for the other line on the rack.(the other line that screw's into the rack and goes across the xmember, then back to the reservior)
http://store.summitracing.com/...w=sku
The reason for all of this is my turbo.I'm running one of those SSautocrap stock style exhaust mani's and a T3/T04E turbo, with a internal gate that I can get only to fit clocked one way.Which is with the Discharge straight down.Also if you look there is a hose that goes from the reservior to the PS pump.It's been ghetto rigged just to get the car started. What is everyone else using for that?Because the size of the pump is bigger than the size on the reservior.
The Problem
Here's my IC piping that I'm gonna be working with.You see the Hotside where it comes up, then makes a vertical 90* left then another horizontial 90* right towards the firewall.Well that pipe needs to be cut up and fixed.
I was thinking that when it comes up out of the fender and makes that vertical 90*, to continue it to a full 180* (short radius) and then make a 90 * towards the turbo.On the turbo I'm going to have a 90* coupler on there facing towards the radiator.
But the High pressure line is in the way of the IC piping.And the low pressure (i think) line is in the way of the turbo. (where the 90* coupler will be going.
Now the problem I'm having is if I get the univeral 3/8" barbed end cooler, how will I connect it to the rack, and then again to the reservior.Which the rubber line on the reservior from the stock PS cooler is roughly 10mm or .40"If I got the universal cooler, I'm sure I could squeeze the 3/8" (.375) line onto the reservior.
Is anyone running a aftermarket PS cooler on their car??If so can you post up your setup?
Thanks
