mkory wrote:Do the rb20's rev faster maybe because they come stock with a lighter flywheel? I can't imagine any other reasons why it'd rev faster.
The RB25 flywheel is actually lighter thant he RB20(Thanks Brian)
There is about a 4-600 RPM difference in between the RB20 redline and the RB25 red line... It takes 10 PSI boost to get 210HP on RB20 and 7 PSI to get 250HP on RB25.
There is no replacement for displacement.
That is why there are stroker kits for the RB26 to go 2.7 or 2.8 liters...more displacement=more power. that is why Nissan Z-Tune Rb26DETT uses a 2.8 displacement and the 400R did the same.
The RB26 is the peak of Nissans technology at the time, that is the reason to use it...because it just plain rocks the house.
HybridOne wrote:with the money you spend on an RB26 you could get an RB20 and upgrade it to higher HP. So your looking at the same dollar amount but instead of the stock 26 you have a built 20.
This may be true but witht he extra stress on the parts from higher boost/lower displacement it may not last as long as an RB26 at the same HP level. Stock RB26 motors are at the extreme low end of the power potential, esentially de-tuned for street use.
rb240sx wrote:I agree, I would rather have a 20, I put a aluminum flywheel on mine and it screams, I love it, an rb25 cant rev as much as a 20. has more rotating mass.
RB25 cant rev as high cuz it dont need to...again...whats 600RPM when you lose .5 displacement and 40HP? People pay alot of money to gain 40HP.
Choose whatever engine YOU want and forget what everyone else says.
I say if you got the green the 26 is the way to go...alot more responsive to mods, alot more wow factor and alot better starting point.
If you aint got the green the RB20 is a good motor and has alot of potential also....just takes MORE money to get where you want...in the end you will probably spend the same amount.
