Cleveland180 »
https://forums.nicoclub.com/cleveland180-u25891.html
Fri Oct 16, 2009 4:41 am
Hello Niconauts! I am a senior in Mechanical Engineering and I am working on an Engineering Economics Project and I could use everyones help.
I am proposing a start up of a company that produces aftermarket intake manifolds and want to get a poll going to see if there is a market.
Now I have done some studying to see whether or not I think I could make a great intake manifold for the Rb series engines and I may actually do some prototypes if I get good interest.
Currently I have three different materials I would consider using, and I will go through each to explain a little on why then If you could vote I would appreciate it.
The reason I chose this as a project is I feel we are getting shafted on the limitations caused by the over the valve cover intake manifold or the Taiwan eBay special that costs $700!!
I would be making two different size intake manifolds, one made primarily for street (lower end, more practical usable power), and one for the Extreme performance seekers (high end power willing to sacrafice a little on the lower side). My proposed manifolds would be Made in the USA and would certainly come with a fit and workmanship guarantee. Prices would be around $550 for a non-coated manifold.
Cast Steel: This method would be great for mass producing and machining a great product with good ductility properties, the more I would make the cheaper it would get.
Aluminum: Lighter than steel, low specific heat, Easier to machine, con coolant can cause some nasty corrosion if not suited for Al. Welding aluminum is a bit less fun.
Tubular Stainless: Heavy duty, but great asthetics, great strength and high durability. Cons, Fatigue on welds and cost of welders and material.
If you guys could take a second and vote I would appreciate it! Leave comments too! I really do wanna get as many opinions as possible!
Thank you !
