RB Engine Coil Retrofit
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
You should leave a loop or some kind of access to the #1 cylinder wire at the 7-pin plug so you can easily hook up a timing light to it. Just a little reminder before you install it and everything.
BoostFab
Car: S13cp, S13fb, S14z
Darius wrote:You should leave a loop or some kind of access to the #1 cylinder wire at the 7-pin plug so you can easily hook up a timing light to it. Just a little reminder before you install it and everything.
no need to, you can clip the timing light to any spark plug cable directly as it'll be exposed.
matafied
Car: 1989 240 rb25det 1992 240 rb25det
well i am very very happy with this set up, only costed right at 100 dollors and it works flawlessly.here are a couple of the installed product
http://is.rely.net/3-117-5386-...w.jpg
http://is.rely.net/3-117-5387-...w.jpg
http://is.rely.net/3-117-5388-...A.jpg
http://is.rely.net/3-117-5389-...g.jpg
http://is.rely.net/3-117-5390-...g.jpg
dont mind the mess im gonna clean it up this weekend
BoostFab
looking good. all you have left is hide the coilpack and the spark wires, no one even notice difference
POOPmouth
Car: The Devils pimp ride
awsome setup- Great job
pdvorak
Car: 1996 240sx rb25det
i have a question about this, when you connect cylinders 1-6, 2-5 & 3-4 together each of them to a coil. does it matter were cylinder 1-6, 2-5, 3-4 are either on the top or bottom of the coil?
matafied
not sure if your talking about the spark plug wires or the trigger wires?? here are a couple paint sketches this might clear it up for you
http://is.rely.net/3-117-5416-...g.jpg
http://is.rely.net/3-117-5417-...A.jpg
pdvorak
thanks, that cleared it up for me.
300Plus
Car: 1995 S14 w/ Rb25det Series II
I wonder how this setup would be wired on a stock ecu RB25 series II
matafied
The same way, you just have to wire in the igniter.Take my word for it, I got curious and ended up frying this chip in my ecu on my daily driver.
http://is.rely.net/3-117-5418-...g.jpg
http://is.rely.net/3-117-5419-...A.jpg
http://is.rely.net/3-117-5420-...g.jpg
Lucky for me I had an extra parts ecu lying around that I cannibalized
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Eewie! Burnt electronics FTL! Glad to see you had a spare!
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
what spark plug wires. i want to mirror your setup as much as possible.
BoostFab
pdvorak wrote:i have a question about this, when you connect cylinders 1-6, 2-5 & 3-4 together each of them to a coil. does it matter were cylinder 1-6, 2-5, 3-4 are either on the top or bottom of the coil?
it doesn't matter top or bottom of the terminal, but as far as the 1+6, 2+5, 3+4 are on its own coil bank. the firing order will be messed up and may kill your engine if you don't. picture it in your head, it's pretty simple.
matafied
KUILLIN_DRIFTER wrote:what spark plug wires. i want to mirror your setup as much as possible.
their accel here is a pic, part # 5040B
DORI-DRFT
Car: 89 S13
Are you using the stock ignitor or did you just trim it?
matafied
yes stock igniter
sinnerstar
Car: Skyline
Nice to see that people are putting my write-up and photos to good use, since theres no mention of my site just wanted to say it came from here http://www.dsd.co.nz
Dan
matafied
sinnerstar wrote:Nice to see that people are putting my write-up and photos to good use, since theres no mention of my site just wanted to say it came from here http://www.dsd.co.nz
Dan
your my hero
sinnerstar
Car: Skyline
Haha cheers, just doing my bit
themadscientist
klh6686 wrote:
The only reason to do this mod is if you are having problems with the stock ones and don't want to spend upwards of $500 on splitfire coils and don't want to spend upwards of $50 per stock coil to have it mess up down the road.
The coils in my sig are up for sale.
tintdude69
Car: 90 Sr20 hatch..
chalk up another successful happy retrofit. for the amount of time and price its pretty much amazing...
-wj-
Car: S13 RB25DET
Matafied !!!
I need your help !
You seem to have the exact same setup as me (rb25det series 1) but you DO have the wasted spark system running!
After installing my kit, it wasn't running on no.4 and no.6
in this picture : http://is.rely.net/3-117-5221-...Q.jpg
I see the exact same 2 plugs I have, the 6pin plug going from the ignitor to the coilpacks and the 2 pin plug with the power and ground wires.
I see that you have somehow connected the ground wire to the 6pin plug !!! How and where ?
these are my plugs : http://www.wjweb.nl/image/DSC00122.JPGh ... C00121.JPG
Need to have this fixed by the end of the week, so kind of in a hurry, don't want to refit the coilpacks
matafied
Yea I think that could be part of your problem, the 2 pin plug on our application is power and timing reference (black wire), their is no ground on the plugs, that black wire on the 2 pin plug gose back to #1 and #6, but their is a ground on a ring terminal that loops around to all the coil packs that’s on the cylinder head, I just used it to ground the bracket I made, so you don’t need it at all, just me being extra anal. Ours is a little different from the diagram posted but essentially the same thing. Also double check your wiring, we all make simple mistakes some times so retrace your steps and don’t loom everything up until your tried it and is working fine. I haven’t had any problems with this on my ride, best mod for dollar ive done. So it dose work, good luck and let me know if you get it strait or if you have any other questions
matafied
this is what i used to ground my bracket
http://is.rely.net/3-117-6254-...g.jpg
matafied
well just thought i would inform those who are interested that i finished my s2 rb25 over the weekend with a ebay ingniter that i scored for 9 dollors lol so it dose work the same on s2 with the help of igniter
http://is.rely.net/3-117-7828-...A.jpgh ... 0-...g.jpg
matafied
ok quick update,i was running this on my car for about a week when i started noticing the car start chopping up in the higher rpm range and it was gradualy getting worse. after some troubleshooting i discovered that the factory rb coil power wire was not effecient enoph to supply the big GM coils. so just to be safe i ran a ground wire from the battery to my igniter ground (center pin on 7 pin connector) and a new power wire from B+ on a relay and used the factory coil power wire to switch the relay. and vala all better i checked my timing and have been driving all week with no problems. so anyone that is running this and having issues no biggie its a simple fix.
the_garynator
Car: 2015 370z Sport
93 RB26 S13 Coupe
96 SBC Hardbody
THANKS A TON!!
I'm currently wiring my new coil up and I'll go back and make sure I use larger gauge wire.
Thanks again!-Gary
StricNyne
how can i make this work with a haltech e6k i have a gm coil and an ignitor but NO harness, but i assume i can use spade connectors, well my harness is the haltech one
StricNyne
actually i found it w00t its part of the harness i just got 5 wires, that are labeled COil-VE, local gnd, 12v ign, and these 2 are the e6k ign output and they are ign signal, and signal gnd here is the instructions http://www.haltech.com/downloads/e6k-manual.pdf and stupid comp wont let me get page
Modified by StricNyne at 3:19 PM 7/2/2007
mott6904
Car: rb20 big turbo big cams s13, 97 kouki, turbo audi a4,turbo busa
Is there any way to take out the igniter when running a wasted spark setup? Also does the polarity matter on the coil?
Modified by mott6904 at 4:25 PM 12/17/2007
