kerrton wrote:williammoses and kcfm (and others):
Did you guys ever discover what was causing that rattle noise in the front end when going over cracks in the road? When I had them check mine out, they said it was the hood rattling so they adjusted it, but it did not eliminate the noise. I've since been speculating that it's two plastic covers, specifically the one that covers the oil filter and there is one on the drivers side too that isn't supported well at all, but I'm not 100% sure. Any thoughts or discoveries?
I'm getting that too, its really only over cracks in the road at steady speed.kerrton wrote:williammoses and kcfm (and others):
Same boat, 2 month old Rogue and I 'll just chalk this noise up to the cons of having an SUV, noisier over bumps.caroline84 wrote:i have 3 mths old rogue and it has a rattle in the rear end. i can hear the noise at low speeds (20-30 mph) when driving over bumps.it's extremely annoying because it's a new car and things are not supposed be like that. having the car brought to the dealership four times the guys told me that everything is acoording to spec and there is nothing wrong with the suspension....but the noise is still there. i requested a test drive with another rogue and the same noise was there. i was told that all rogues have the same type of noise and i will just have to get used to it or turn the radio on...yeah great im stuck with a junky car:(
Hey Kerrton,kerrton wrote:Hey Couz,
I brought my Rogue to the dealer with this problem, and they said they solved the problem by adjusting the hood latch. My hood seems to be latched very securely now, however I still get the VERY annoying sounds EXACTLY as you've described so this didn't solve the problem.
I've wondered if it's those stupid floppy plastic gaurds on either side of the front end - one of them covers the oil filter on the right side and the other is a mirror image on the left side, and they meet with the main plastic guard at the front under the radiator and with each front wheel well plastic gaurd. One edge is totally unsecured so the stupid guard just flaps and vibrates around all over the place, every time I look at it it annoys the hell out of me because it looks so obvious that it's a bad design and I'm disappointed in it. I could've bought a cheap GM product like a Pontiac Torrent and then at least I wouldn't be surprised by this crap, but Nissan is really trying my patience with all these little things. To add to this the cover for the drivers speaker rattles like crazy and I have to beat the crap out of it to shut it up on a regular basis, so this car has got me in a bad mood lately....... please let me know if you do find a solution, thanks.
Your hood should definitely be snug, mine wasn't even close, that sucker will rattle on tight cracks even if there's a little give and play.kerrton wrote:Glad to hear your problem is solved!! Now that you're getting the little bugs worked out I'm sure you'll be loving the Rogue.....I'm going to check my hood again, maybe I can tighten it further and see if the noise disappears. Happy cruising!
OMG !!!!boooey wrote:I have posted this in other "noise" threads also..
I almost always hear some kind of plastic flapping/rattling coming from somewhere inside the upper dash console now, and it seems to be worse on very hot days.
I have never been able to pinpoint it, but it sounds like its coming from behind the 2 air vents above the radio.
its so annoying...
