Ok Peter I'll play your games!Peterofdevon wrote:Many G50 owners have modded their suspensions.
Lets have a thread rating the efficacy of the mods. Here's an initial list:
FSTBTokiko BluesSway barsadjustable multilinksbushings???
On my Qs the Tokikos make the most profound difference followed by the FSTB and rear sway bar---laugh...its all I've done so what do I know!
Would it be a good idea to create a list and and have a rating vote say 1 to 5 for each mod? Is this a good idea at all? Perhaps I need to get a life.
Peter
While the rear suspensions are quite similar, the FY33, Y34 and F50 have the same MacPherson Strut design, really quite common and not in the same league as the G50 sophisticated multilink. Haven't really cornered an F50 hard, but I will say the 2000 FGY33 does have more roll resistance than the G50. This does not necessarily mean the constant radius skidpad g forces are higher, as that is more related to weight, and the F50 is not much lighter than a G50, if any at all. Lots of goodies in the later cars weigh a lot when added together.StarPD wrote: suspension improvements and other factors still put the F50 ahead of the G50 in the handling department.
Interesting. I haven't been under my 2005 Q45 yet, but I wasn't aware that it has a rear sway bar, and possibly even a rear strut brace. I'll have to check that out. If that's the case, I suspect that there's something I can do to replace or stiffen the sway bar to reduce the only thing I don't like about the car: understeer.maxnix wrote:While the rear suspensions are quite similar, the FY33, Y34 and F50 have the same MacPherson Strut design, really quite common and not in the same league as the G50 sophisticated multilink. Haven't really cornered an F50 hard, but I will say the 2000 FGY33 does have more roll resistance than the G50. This does not necessarily mean the constant radius skidpad g forces are higher, as that is more related to weight, and the F50 is not much lighter than a G50, if any at all. Lots of goodies in the later cars weigh a lot when added together.
Pretty sure the F50 has a rear anti-sway bar and probably a rear strut brace.
I agree about the steering, and even asked somewhere if anyone has any suggestions to tighten up the steering and make it a little more responsive and provide a little more feel. I think this may be another area where tires can help. I'm counting on that with the new wheels/tires I have on order. I'd still like to pursue other means too though.Q45man1 wrote:Yeah I wish there is a thicker rear sway bar available for the F50. I just have a minor change in the suspension by installing a lowering springs and stayed with the factory shocks. In the handling department, cornering improves a lot but the steering response needs improvement. My F50 still feels disconnected and the steering feels numb. My G50 steering response is more responsive and connected.
Even with the 200# weight difference and lower cg?elwesso wrote:it just makes you feel more confident... REMEMBER that the G50s suspension setup would be different if it had 17 or 18in wheels vs the 15s... It would need much less camber gain to maintain an ideal contact patch.
Still, its neither here nor there... however, I think stock vs stock on the same tires the G50 would outhandle a F50.
Wow your suspension must have been shot... Seriously, give them a few months to break in.. They will get much smoother once summer rolls around, trust me. The first few months with the blues is quite different especially if you're used to a worn out suspension.Blamecanada999 wrote:I don't have much to add to the topic, besides the statement that I'm very unhappy with my Tokico Blues. One of my front struts went, and it was cheaper to put 2 Blues up front rather than replace the one broken strut with OEM parts. Since their installation, ride quality has suffered greatly. My Q rides like a truck. It's to the point where I fear it's having adverse effects on other components of my suspension. I'm sure if I were to install other performance mods, the Blues would come into their own. I don't have any desire to though. The G50 is a luxury car, and that's all I want out of it. There isn't any real discernable difference in handling either, meaning the cons definitely outweigh the pros.
Honestly, 200lbs is not that much of a difference on a heavy car, its like having a 1/4 full tank vs a full tank... I think the weight difference is probably closer to 100lbs, but we'll call it 200 for arguements sake..StarPD wrote:Even with the 200# weight difference and lower cg?
Perhaps. Frost heaves are the norm here; and when driving on bumpy roads, I can get some pretty bad bump noises from the back end. I assumed the stiffer setup up front changed the suspension dynamics and the OEM rear shocks were having a hard time coping. Maybe it's time to replace the rears too. Looks like I may have another Spring project. I'll have my mech check everything out back when I get it inspected next week.elwesso wrote:I wonder if part of your problem is worn out rear shocks?
Did you replace all the rubber compnonents? Also, if the upper links, steering rack bushings, tension rod bearings, etc. are not up to OEM as new standards, your ride will suffer.Blamecanada999 wrote:I don't have much to add to the topic, besides the statement that I'm very unhappy with my Tokico Blues. One of my front struts went, and it was cheaper to put 2 Blues up front rather than replace the one broken strut with OEM parts. Since their installation, ride quality has suffered greatly. My Q rides like a truck. It's to the point where I fear it's having adverse effects on other components of my suspension. I'm sure if I were to install other performance mods, the Blues would come into their own. I don't have any desire to though. The G50 is a luxury car, and that's all I want out of it. There isn't any real discernable difference in handling either, meaning the cons definitely outweigh the pros.
Suggestion:Q45man1 wrote:Two weeks ago I replaced my OEM shocks with Tokico Blues and put in new boots and mounts. What a difference in handling area. The ride is a little bit firm but the quality of ride is not lost. I love it!
All I have to now is to change to a high performance tires (16+) and install a light weight rims.
Percy
OZ Racing 18x9 +35 and 255/40-18 PS2 about 45 lb. each and $2500 without alignment.StarPD wrote:The cast TSW 18" "Kyalami" wheels and Bridgestone RE050A Pole Position tires I'm putting on my 2005 Q weigh combined around 60# each, and will cost me OTD $2600. Better and lighter wheels and tires would jack that up considerably.
The forged 18" BBS RG-R 18x9's I recently pruchased (from NICO sponsor http://www.tirerack.com) were less $$, but the shipping weight was ~50 lbs each. Though I think the one legible label also included 20 lugnuts.maxnix wrote:OZ Racing 18x9 +35 and 255/40-18 PS2 about 45 lb. each and $2500 without alignment.
I get $942 each for BBS RGR and 255/40ZR18 PS2s.That's $3768. Road hazardwarranty is $137.76. Add in shipping, mounting and balancing, and sales tax, and cost is well over $4,000, pretty much as I mentioned. Unfortunately, I would have to like the wheels, and I don't care for the RGR that much, especially not for $4,000.Rex wrote:
The only OZ wheels I'd put on my car are the Superleggera III; $874 each plus $287 for PS2s. Add in shipping, road hazard, mounting and balancing, and sale tax, and I'd be up to over $5,000.maxnix wrote:OZ Racing 18x9 +35 and 255/40-18 PS2 about 45 lb. each and $2500 without alignment.
While I expect to be happy with the appearance of the TSW Kyalamis and RE050As, I'd like to be able to afford the OZ or BBS forged wheels with PS2s. They're just not in my budget right now.maxnix wrote:I put the PS2 and OZ Superleggera on my wife's car. No compalints, believe me. The RGR are a steal for forged, but the OZ are as good as any cast wheel.
The Super Leggera III are heavier (like the BBS LM 3 piece), but probably stronger.
The truly trick wheel is the NISMO MAG Star, but it is a little more expensive. About 16 lbs. in an 18" wheel!
Thanks... im bought a set except they were 18x8 and 18x9 ET 35 and 38.... Dont think you can do the 9s on a front of a G50 unfortunately.. They should fit nicely, and they are a different kind of look than what my Q is used to. Going to run 255F and 265 or 275 rear, havent decided on my rear fit yet.maxnix wrote:Well, they are on the FY33, but in my test fitting on the front of the G50, I wouldn't go any more towards negative.
I like them as they are llithe, and show the caliper very well stationary and rolling. The 255-40 look like they were made for that width.
The only thing that gives me pause on the Ultraleggera is the spoke is extended so it protrudes from the rim itself. But they are strong and true.
Superleggera no longer in production. Not to be confused with Superleggera III 3 piece forged, which TexasOil has on his SL600.
watch those pole positions. Treadwear is horrible. I just put a set on 15k ago and they backs are BALD, fronts are worn to 30%. I was VERY dissapointed with my $1000 worth of tires. My fault for not checking treadwear.StarPD wrote:FWIW, my new to me 2005 Q45 corners a LOT flatter than my old '94 Q45t with new OEM shocks and bushings, stock BBS "lace" wheels and Yoko AVS-DB II new tires.
The 2005 does have 20" wheels and 245/35 tires, which I'm changing to 18x8 chrome TSWs with Potenza RE050A "Pole Position" tires, so it remains to be seen if it will still lay as flat in corners. Perhaps the semi-active shocks on the F50 contribute to the flat cornering, even on the "Auto" setting.
I sure wish someone made a Rear sway bar for the F50.
Only thing they came close to was the fender. But didn't rotate the steering wheel. Stock springs.elwesso wrote:Dont think you can do the 9s on a front of a G50 unfortunately..
