IanS »
https://forums.nicoclub.com/ians-u23642.html
Fri Mar 15, 2013 7:57 am
Make sure all the wiring harness grounds are in and good. IIRC there is a ground from the harness to the intake manifold, a ground from the harness to the chassis behind the headlight, and a ground from the harness to the firewall behind the valve cover. You need them all or the ECU won't have enough power to turn on the main relay for the fuel pump, or the coils.
