Ran it at the track..
cyris3d
i finally got to run it at the track..best time of the nite was a 13.8 @ 103.. with a 2.2 60ftthats at 8psi.. Boost controler took a ****.. so thats all i could runand third gear i have to granny shift into due to a worn out bushing making the shifter sloppy... all and all.. im pretty happpy.. next week the new turbo should be on.. and ill have a new boost controller..
Night says he went 12.6 on street tires.. at stock boost... i call BS..
Nameless EJ6
Car: What the **** do you think.
13.8 is pretty damn good IMO. I'll bet you can do alot better with more practice and your shifter fixed. Plus that turbo.
I doubt Night did that too.. but I thought he had slicks on? Maybe I read it wrong somewhere.
Nice job for now..
93RPS13
Car: Cars, Girls, Cars, Food
sweet
nlzmo400r
Car: '02 Nissan Altima QR25DE
'93 Nissan 240SX hatch KA24DE
thats awesome, what kind of tires are u using?
93semax
cyris3d wrote:i finally got to run it at the track..best time of the nite was a 13.8 @ 103.. with a 2.2 60ftthats at 8psi.. Boost controler took a ****.. so thats all i could runand third gear i have to granny shift into due to a worn out bushing making the shifter sloppy... all and all.. im pretty happpy.. next week the new turbo should be on.. and ill have a new boost controller..
Hmm that's kinda dissapointing. I would think a S13 would run deep 13's and s14's run mid 13's. What was your race weight?
aznromeox
Maybe the tires........It seems you have a LSD with your 2.2 60ft. Is it possible to get even lower w/ street tires?
cyris3d
im using nitto 555r drag radials.. and have a r33 LSD... i hit a 1.9 60ft.. but missed thrid that run.. im deffinitly sure itll go deeep 13s at 8 psi.. and 12s at 12-13 psi
DCIracer
What other parts do you have Cyris? Just a stock engine with stock boost isn't going to pull heavy numbers.
Bryson
Car: 93 240sx Hatchback /w Sr20
Cyris u still have bad compression right??
nlzmo400r
well as far as nitto555r drag radials, it wont get much better for a street tire, also, 1.9 6oFT time is awesome, just concentrate on not missing third next time ;), practice makes perfect, keep runnin her bro, im sure at 13psi you'll hit about 12.7s or so
DCIracer
Or if you improve your compression by replacing your head gasket or whatever else is causing a low compression problem, you'll see a lot more hp and a lot better run.
cyris3d
i havent checked the compression since we got it started.. gotta do that soon..
1.9 was ok.. but i didnt even launch that hard.. i know 1.7s are possible..
hoping to hit low 12s maybe 11s with the new turbo
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
Wow, I am amazed at your times. Or better yet, the times that you are capable of, just haven't ran. Nice work.
Bryson
Cyris I thought u did a compression test and they were all in the low 130's and one was even lower??? I'm lost man :( I'm sure wondering because I'm hoping thats the only reason its going slower than expected
Bryson
It says your on so I'm hoping u answer my Q about the low compression.
cyris3d
yea.. we did the compression check when the motor was in the clip still.... and it was really low..
hoping now.. after the motor running for the while.. the oil set back into the rings.. and the compression will be up where it spodda be..
Bryson
ahh ok
DCIracer
I'd still replace the headgasket or piston rings anyways. That can be the main problem why you are not hitting mid 12's to high 12's right now anyhow. I had a 1991 240SX that was running mid 18's because of bad compression. I had a friend with another 1991 with less aftermarket parts on it than my 240 and he was running low 17's. That's a full second and a half difference just because he had excellent compression and I didn't....
cyris3d wrote:yea.. we did the compression check when the motor was in the clip still.... and it was really low..
cyris3d
pic from the track
DCIracer
Nice looking sleeper lol. Gotta love when a stock looking car comes up and smokes everything else at the track.
spec-v5150
DCIracer wrote:Nice looking sleeper lol. Gotta love when a stock looking car comes up and smokes everything else at the track.
LOL so true. My car is a bucket. I have oxidation , a few sccratches, a dent in the door. Overall lackluster looking 240.
nlzmo400r
but still a good looking car, looks like u have a lot of road tar on those rear quarterpanels, get some gasoline and that **** comes right off, great times, and cool wheels too!
lbrowne
nice times, what elevation is the track?
cyris3d
well since my compresion is low.. and you sold me the motor.. shouldnt you do something about that???
hashiriya13
Car: Cars, Racing, Cars, Racing
So what was the whole run like? meaning 1/8 time also. Just checking because thats all I have been able to really run. (tuning issues but soon to be rectified) I have got a 2.0 60' and a 9 flat with the car acting up. But with street tires I dont see mid 12's at stock boost but you never know. So are you in vegas?? If so I may be heading that way for one of the next holidays maybe we could meet up if I make it that way maybe even hit the track if open.
cyris3d
cyris3d wrote:well since my compresion is low.. and you sold me the motor.. shouldnt you do something about that???
what you told me was that u have a mechanic friend... and he said it would be fine.. after it ran for a while.. and that was it...
and hash.. thad be deffinitly awesome.. lemme know when your comming.. ill be able to let ya know whats going down....
hashiriya13
Sweet my next chance would not be until around thanks giving but I will get there and let you know.
GODSILVIA
If you are hittin 13's on stock boost thats not to complain about and all this loosing compression talk tells me you are going to hit some better times when you get the problem fixed.
My 240 hatch with stock rb26dett ran 12.3 @ 118 mph on 17 psi and a street tire one legger. I just completed my headwork and am putting the car back together and we'll see what I can pull after that.
Bryson
wow if u get a GTR LSD installed I'd bet you'll run mid 11's.
vududoc
Car: drag drift autox
wat size rims? as that will change final drive also. but compression is the factor. track temp also kills performance. there are a bunch of little things but i think it was a nice run...im more focused on you upping your times.
