Ran it at the track..
Touring240
cyris what size rims are though and what size nitto555r
thanks
cyris3d
17inch rim.. with 245/45s
Altiman94
Car: 1989 Nissan 240SX
I'm extremely impressed with all your cars. 12's is incredible
JeffTN
Car: Autos and snowboarding
cyris3d wrote:i finally got to run it at the track..
How did the clutch feel? Any slipping? I would have imaged that you would have mentioned in, but I am just curious. I just wonder what the condition is of the clutchs in these clips that have been sitting for who knows how long.
cyris3d
seemd fine with the stock turbo.. now with the t3/t4 there is a lil bit of slippage
JeffTN
Have you thought about what clutch that you are going to upgrade too yet?
cyris3d
mack seems to really like the OS Gilken cluth.. so im thinking of goin that route.. either that or the ACT Clutch kit
S13Sil-line
Car: Full throttle-*** out sideways
Jim Wolf Tech. has a clutch for that transmission for $550 dollars. It comes with the pressure plate and holds over 500 lbs tourqe. If you call them its the 300zx n/a clutch for the RB25. They will know what one you are talking about.
Nameless EJ6
Car: What the **** do you think.
You should try the ACT and report back. I'm going to go with that one...
nlzmo400r
Car: '02 Nissan Altima QR25DE
'93 Nissan 240SX hatch KA24DE
a friend of mine has an ACT clutch, and his was slipping after 2weeks... o, yea, he has a 12.8sec evo8 (4wheel drive kills ya)
Altiman94
I have heard a few bad things about ACT, but alot of people dont properly break them in causing all kinds of problems, too.
Bryson
Car: 93 240sx Hatchback /w Sr20
altiman has a point, Nizmo your friend's clutch probably began slipping like mad after only 2 weeks because he didn't go easy on it for the first 500. I've heard it is EXTREMELY important to do this, and I doubt if it is a car he drag races and its on;y been in there two weeks, that he babied it for the first 500.
Joe
yes breaking in the clutch is important, all the components need time to settle before you go launching and beating on it.
Nathan
Pucked clutches dont need nearly as much of a break in period :D
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
HEY CYRIS I SAW YOU NEEDED AN INTAKE MANIFOLD. I HAVE THE ONE OFF OF MY RB25DE IF YOU WANT IT EMAIL ME, WE CAN WORK SOMETHING OUT: [email protected]
THEY ARE THE SAME SETUP AS THE TURBOS.
fly240
Car: nissan 240sx
Hey cyris, how come my rb run like a stock eclipse only on 8psi. I don't feel that my will hit 13 or 14 second. Right now my car is every thing stock.
any helps will appreciated.
apex_7
Car: 240sx
I hit mid-high 14s my first time to the track. IMO, It's all in the launch. I finally got a 13.9@102 w/ a 2.2 60ft on street tires. My clutch was slipping really badly too. What clutch is a cross-reference to the RB20. Is it the 300zx TT or NA? Thanks in advance.~Tony
PROJECTRB240SX
ITS NA, THE PILOT BUSHING IS A TIGHT FIT THOUGH.
S13Sil-line
You can pick up a JWT clutch for $550 that hold over 500 lbs of tourqe.
nlzmo400r
thats a damn good price, what transmission is that for?
Bryson
I'd imagine its for any of the RB trannies.
S13Sil-line
I know for a fack it fits the RB25. From what I hear, they are all the same except the RB26.
Bryson
I think even the 26 is the same. You can bolt an RB25 transmission to the 26 so why not?
nlzmo400r
im with bryson on this one, i know the 25 transmission bolts up to a 25, so i dunno, however the only difference is the 26 is 4wd
S13Sil-line
I know the 26 bolts up to the 25 transmission but I guess that would make sence.
nlzmo400r
right, but the 26 transmission is 4wheel drive, so it makes it different
Nameless EJ6
nlzmo400r wrote:right, but the 26 transmission is 4wheel drive, so it makes it different
Explain how. None of the parts within the AWD system interfere with the clutch...
nlzmo400r
this is true, but its usually better to run a stroner clutch with AWD as the clutch genrally has to grab haardre because there won't be much wheelspin. Either way, we need to just get someone to clarify whether or nort this clutch wold work for the 26 transmission as well as the 25
Bryson
you do know that the skyline isn't real AWD right? Its most always RWD with the occassional AWD when it loses traction.
Though I'm sure you knew that.
PROJECTRB240SX
THE RB26 FLYWHEEL IS THE EXACT SAME AS THE RB20'S THE CLUTCH SYSTEM IS STRONGER THOUGH. THE RB26 CLUTCH IS ALSO A PULL STYLE AS OPPOSED TO THE RB20 PUSH.
