Hurrikane wrote:ok so ram air does not work. so turbos.supercharges and NOS dont work to.after all all thay do is speed up the air and add psi to the intake.ram air does this but in smaller amounts.you may not gain hp but the hp you have will stay the same at higher speed and the motor will not have to give up hp to intake air.as the speed of the motor get higher it takes in less air .the ram help to keep the same amount of air flowing. I have been a A/C tech for over 18 years i work cfm.and air speed every day.the problem with most rams is that thay are to small to work right. a frind has a camro with this setup the hood part is nice and big but when you open up the hood the runners get very small and that not much help.and as for bikes (I DONT KNOW S***) arent thay 2 strok and car are 4 strok right.
I'm with you on the fbody ram air setup. But the part about turbos must not work according to that article is not valid.
Air rushing at a car trying to come through a port/hood nostril is by no means the same as the pressure a turbo applies. I'm not trying to flame you but that article I posted is not BS.
Most times ducting air into the engine bay like most people want to do, is just a glorified cold air intake setup.
But the original argument is to shed light on the 'ram air' thats supplied in autos. I too used to think different until I spoke to many people on the subject. If I were to convert my car to a Ram Air setup, I'll actually lose hp compared to the K&N FIPK that I currently run now. (I'm talking about my TA that is
