schroder wrote:LOL...Thanks. I didn't know I didn't have them enabled, so I'll have to look around...plus this may help the community and thats never bad
Its the US style rally cross, and most are pretty tight from what we run. I was looking into I/H/E and reducing as much rotating weight as I safely could. Is there anything else that would help the car expand the powerband specifically (on the 24e?). Also, what would help to get the rear to dig (I assume squat) better than just running stock springs? Also, since suspension is so important with rally cross, would a poly bushing set help or hurt the car? I know it reduces flex, and I assume it would benefit by making the car a little more predictable on the unpredictable surfaces, but didn't know if it would be a negative at all. Thanks for your help with everything man...I'm sure I'll have more questions about it, but that really helps!
Ok...One more...how competitive can the 240 be with the 2wd cars, obviously with decent tires.
Reducing the cars weight overall should be your biggest modification. Every ounce counts. Since you wont be requiring a cage, getting the car to be feather light will be your best chance at speed. As for building more useable power, I would look at increasing compression, and re tuning. If you were to increase compression significantly and make a switch to E85, you could run lots of timing to help build power early.
Leave the suspension stock, rally cross is about getting traction where there isnt. Look into what guys do to go fast on ice.
Being competitive is a toss up. By the books a fwd car will be faster on a rally cross course if power and weight are the same, but the right driver can do incredible things. When I built my car, people told me I would lose because RWD cars are only competitive with FWD cars when power levels, and speeds get higher. At our first event, I was able to outrun much of the FWD field including a couple cars with more power, and more experience then myself.
My advice. Gut the car as much as possible, lose everything. Get a good set of winterforces, and some bolt ons, then get out and drive. Only way to know how she will do, is to try.
