Radar detector hard wire
shortys408
Car: '11 M37S
08 altima coupe 2.5s - *Sold*
I recently purchased an escort 8500 x50 from a police auction for 150$. I ordered the hard wire kit and suction cups from escort radar and they came in today. I ran into 2 problems when hard wiring the radar. the first problem is the hj11 cord is about a foot 2 short. I think a female to female adapter will fix this problem. My other problem is I do not know what wire to tap into. It came with instructions on how to do it but i dont know which one to use. I figure the cigarette lighter in my arm rest would be the best bet but does anyone know how to get underneath there?
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
why not run it to a fuse under the dash?
shortys408
Car: '11 M37S
there is already an inline fuse.
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
i ran my wire from:
The sun visor
Down left A pillar behind the cousin/rubber
Behind the dashboard
Then into the cigarette lighter in the dash storage area
The picture with the yellow line is the full route i ran my wire. Imagine your looking behind the steering wheel and all that. Hopefully this will help you
SE5907
If you have an auto-dimming mirror, check this out: invisicord.comI bought mine last week and it literally took under 60 seconds to install. Can't recommend it enough.
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
Holy crap, no kidding. That looks like a great product!
notaverage
Car: Altima Coupe 3.5 SE w/ tech pkg and VDC. Precision Grey
Wow, I really like that Invisicord!, but $19 for a 2' cord is kinda expensive. Now where can we get that mount?
SE5907
notaverage wrote:Wow, I really like that Invisicord!, but $19 for a 2' cord is kinda expensive. Now where can we get that mount?
Here's a cool mount:http://www.countryjoycrafts.co...r.htm
However, I have my Valentine One mounted high in the tint band for optimum performance and theft deterrence. Looking from the outside of my A/C, you can't even tell I have a radar detector. It's nice to not have to take it down every time I go somewhere.
ChiLLaXtodaMaX
SE5907 wrote:If you have an auto-dimming mirror, check this out: invisicord.comI bought mine last week and it literally took under 60 seconds to install. Can't recommend it enough.
how do you get to the autodimming mirror harness? Looks easy!
LongBeachCoupe
2005 Lexus RX
their site looks a little odd...
notaverage
$40 for a mount? No Thanks. I can't find that Mike's Mount website, where he sells them for around $20.
SE5907
Just turn the mirror until you can see the back, squeeze with your thumb and index finger and pull it out. It's pleasantly easy.
shortys408
Car: '11 M37S
you know where the trunk release button is. there are 2 empty spots next to it in my dash and i would like to put my power led and mute button for my escort there, does anyone know how to remove the peice in there so i can work on it?
shortys408
Car: '11 M37S
i tried using a flat head but i just cant get it to come out.
G35JCole
Car: '07 G35
I'm not sure if it is the same (though I suppose it is), but I have a G35 and I bought my cord from stealthcords.com
Great service and fast shipping.
It was very easy to install...much easier than running a cord to the fuse box. It took like 60 seconds and it taps into the back of your powered mirror.
Just my $.02.
EzeebMOS3
Car: 08 3.5 Altima coupe Black Pre/Tec/CVT 35%/20% tint, Injen intake, Nismo Cat-back, Eibach proline spr
I just bought an 8500 passport as well. When tapping into the mirror can you still use all the features, such as the Garage openers? And is there anyway to keep the mute button function located on the A/C power unit? I really like just being able to hit it rather ran reaching up to the radar.
LongBeachCoupe
2005 Lexus RX
Id assume the mute button (i know how convenient it is) is no longer an option.. you wont be using that plug... my guess is you would have to touch the button on the detector....
EzeebMOS3
I actually found a hard wire kit for Escort model radar detectors with the mute button attached, im gonna try to use that set up if any.
http://www.escortradar.com/shop.htm
LongBeachCoupe
2005 Lexus RX
But you need to hard wire it lol... this is the plug-and-play version... no cords (also no handy mute button tho)
ChiLLaXtodaMaX
oh wow... I just checked to see how easy it was... it is AMAZINGLY easy to install.
stealthcords.com or inviscord? anyone have a preference? I'm getting the Passport 8500. Which pins need to be connected on the harness connector?
EzeebMOS3
Has anyone used the Escort Passport G-Timer (gt2)?? And is this a solid product, i find it pretty cool. I bet it cant be that accurate. I found some on ebay for wicked cheap.
http://cgi.ebay.com/Escort-Pas...wItem
only $58
Plastics
Car: 2007 Honda Civic EX, 1999 Dodge Caravan
Hello Adidas and Shorts I also have an Escort 8500 X 50. I place mine similar to Adidias on the left edge of the driver side visior. The wire goes down the A pillar, hidden under the vinyl/rubber edging. I connected the wire to the fuse box right on the left under side of the dash. I tapped the hot wire to the fuse marked "10A Audio/Mirrors" and grounded it nearby. Everything works fine.
hope this helps
Plastics08 3.5 SE coupe black Premium
G35JCole
Car: '07 G35
You would lose the mute function unfortunately, but what you gain from not having to run a wire around your windshield is worth the sacrafice...I think. Plus, on my radar detector it is a simple press of the front side of the screen to mute the sound.
I say check out stealthcords.com, where I got mine. It was really easy to install.
MuranoRulz
the invisicord has been around a long time, and has a great reputation, you might want to contact them to see if they have directions for you and the prices are very, very good. They were very quick to respond to my questions when I needed some help.
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
That inviscord product is actually using a technology we've been using for years in the Networking business. POE or Power over ethernet.
Here's an idea..how about not speeding. If you do that, you guys won't need a radar detector. Just a thought....
adidas2go
Hypocrite
So you bought a 3.5, injen's intake, and stillen's cat back because it all looks pretty? You know you speed in Nowhere, Pennsylvania
Mr_Coupe
Car: 08 Code Red 6 speed manual transmission 3.5 v6 Altima Coupe
hey adidas aren't radar detectors illegal in cali?? and if u get caught with one what is the fine? i want one but the NYPD with their unmarked crown victorias, chargers, yellow taxi cabs, and orange easy passes are all over the place
dangeris
08 BMW 328xi Coupe
90 300ZX 2+0 NA
adidas2go wrote:Hypocrite
Yeah adidas, I do speed in Nowhere Pa. but not so fast that it would warrant me having a radar detctor. When I travel to work, my speedo is set to 70mph. Speed limit here is 65mph. Everybody knows that there is a 5-7 mph buffer when statey's clock people. This buffer takes into a account that every vehicle is made differently. So I NEVER get pulled over! As side from that, I'm too old to be hot rodding around. I did that when I was younger, so did it done it. It's hard on the car, and on the wallet if you get caught. I don't care if you do have a radar detector, it'll never matter if they are using a radar gun. As soon as they pull that trigger, it's game over.
BTW,..I bought those items because I love cars and performance NOT because they look pretty. If that was the case, I wold of boought a 2.5! I plan to track this someday when it is all set up. I own a couple of racebikes and I use them to it's fullest potential but that's on the track. On the streets, I try to obey the traffic laws where ever possible.
notaverage
Mr_Coupe wrote:hey adidas aren't radar detectors illegal in cali?? and if u get caught with one what is the fine? i want one but the NYPD with their unmarked crown victorias, chargers, yellow taxi cabs, and orange easy passes are all over the place
Nope, Radar detectors are legal in CA. Radar JAMMERS are illegal. I own a Bel Pro RX65, Great detector
adidas2go
a radar gun is the same whether its on a cop car or a cop on the side of the road holding it. I think you are referring to a Laser type speed trap. There is no escape from a Laser. However there are very very few police officers that actually use lasers. Since you have to actually stop and hold the laser gun out the window. Most police are way to lazy. For me, my radar detector has saved my *** many times, and on wide open roads in Cali it helps. Just seemed like a pretty hypocritical statement to me.
