Racingline's surprise!
mcheddadi
Car: R8
Just a heads up, I might be prototyping something cool from Racingline at this years carlisle if I get it in time!
Now you guys just have to guess what it is :p
hint: it's adjustable
infused305
Car: Nissan A/C 2.5s w/cvt fully loaded
coilovers?
legend_217
Car: 08 Altima Coupe 3.5 black
sway bar. hehe
losenone
Car: AC 3.5 CVT K12
+1 for coilovers
ZeroR
I think I just saw Taz from Racingline mention (in another forum) that rear sway bars are indeed coming soon. But he did not mention anything about being adjustable.
Anyways, mcheddadi, you are so lucky to be first running yet another new Racingline product.
OT: I'm surprised I haven't seen your car around yet considering we are in the same city. I'm sure if I did see your car, it would be hard to miss, especially with those wheels!
mcheddadi
Car: R8
ZeroR wrote:I think I just saw Taz from Racingline mention (in another forum) that rear sway bars are indeed coming soon. But he did not mention anything about being adjustable.
hehe
I'm hard to miss. I think I'm the only blue altima coupe in all of quebec city lol. I've seen only two others but they where in montreal
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
i beat you to the punch mcheddadi, i had mine installed today and took it for a spin! you'll like it when you get it living in the same neighbourhood as Taz has it's perks
mcheddadi
Car: R8
Blackmobile wrote:i beat you to the punch mcheddadi, i had mine installed today and took it for a spin! you'll like it when you get it living in the same neighbourhood as Taz has it's perks
damn soo fast!!!!
I hope mine gets here soon lol
phobs
Nice, how thick is it?
mcheddadi
Car: R8
phobs wrote:Nice, how thick is it?
Bmore-coupe
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
PHENOMenalVinyl
Car: 08 altima coupe 2.5 mt
legend_217 wrote:sway bar. hehe
its an adjustable rear sway bar bc they said a while back they wanted one that you were able to adjust
crayzitalian3
Car: 2007 Nissan Altima 2.5S
if this is a rear sway bar, would it fit the sedans, and if so, how would you think this would do against Stillens?
Boilermaker318
Car: Super Black Altima Coupe 3.5SE
I was thinking Stillen's RSB would be my next mod, but maybe I will wait for this.
Alt.ImaCoupe
How is it adjustable? By varying to attachment point to the end links?
Colton92
Car: 2008 Nissan Altima Coupe 2.5S - WinterFrost
Bmore-coupe wrote:
Blackmobile
yeah two points on each side to attach to the endlinks. that way you can acheive more stiffness from your thick bar
dangeris
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Blackmobile wrote:yeah two points on each side to attach to the endlinks. that way you can acheive more stiffness from your thick bar
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
Auy Gavelt!lol
mcheddadi
Car: R8
I got it! It's super beefy too, I'll go install it
LongBeachCoupe
2005 Lexus RX
What are those 2 brackets for?It comes with free frosting/hair gel too?
One Crazy Max
Car: 2007 Nissan Altima 3.5SE 6MT
it seems those are stronger brackets to mount those bigger sway bar bushings onto.
how big is the bar, in mm?
the stock one is 18.1mm, the racingline bar looks to be about 20mm thick.
did he send you new endlinks to use with it, or are you gonna stick with the ones you already had from racingline?
One Crazy Max
never mind what i just said.
i just looked it up. from the picture that mehdi posted, the bushing says 7/8in, so that converts to 22.225mm, so thats pretty decent, and being that it is adjustable makes it even better!
i had an idea in mind though. Progress makes a 24mm RSB for the 04-08 maximas, so i was going to try and test fit that onto my car. its not adjustable, but it is really thick, and it would improve handling tremendously because it is also really stiff!
now im not sure which one to be purchasing. Progress 24mm RSB, or Racingline 22mm Adj. RSB???
Blackmobile
you also have to keep in mind the material being used. what does progress use? and do you know if the maxima rsb will fit the altima?
One Crazy Max
i had a progress bar on my 99 maxima and it was solid steel, and to my knowledge all of their bars are solid steel.
from what i know, the bar should fit since all FWD nissans from 02-current share the same rear suspension setup. the only differences between the bars are the mounting angles and directions of the sway bar endlinks
mcheddadi
Car: R8
One Crazy Max wrote:never mind what i just said.
well I couldn't do it today. I'll do it first thing tomorrowthese are prototype bars, and I'm using the racingline endlinks. from what I understood is that for the "softest" setting it's going to be 25% stiffer and for the hardest one its going to be ...a LOT MORE Stiffer lol.I'll try to go with the hardest one tomorrow.
I'm going to try for some Snap-liftoff oversteer
Blackmobile
One Crazy Max wrote:i had a progress bar on my 99 maxima and it was solid steel, and to my knowledge all of their bars are solid steel.
was it just regular steel? racingline uses carboloy steel, much stronger for the torsional stress put onto the sway bar. after having racingline's sway bar on, i can say that i don't think i could ever go back to stock, i'm just having too much fun!
ESP
Car: 2008 SexyBlack A/C
Do we have an approximate price for this yet?
One Crazy Max
so you have the sway bar already.
progress uses some sort of alloy steel, as it says on their website. not sure what kind of steel, but thats what it says. heres another quote from their page.
"Progress Anti-roll bars are cold-formed in-house using our custom-built precision bending equipment. Both laser-cut and CNC bar ends are MIG welded in place using a precise fixture for an exact fit."
