Racingline »
https://forums.nicoclub.com/racingline-u84514.html
Fri Oct 24, 2008 7:37 am
Generally speaking, a properly designed performance sway bar will have a larger effect initially on the performance of the vehicle.
The issue is that the stock endlinks are put at an adverse angel an are much more prone to binding, which will (a)wear the endlink much faster (b) not allow full performance of the sway bar due to the angle the link is situated. The best position for the endlink is as close to 90 degrees as possible which under stationary load.
The benefit of our endlinks shows as follows:
--Adjustable length--reguardless of vehicle height they can be adjusted to reach the 90degree goal, since they can be longer than stock or shorter.
Then longer you make them while still at or close to 90 degrees is what will apply extra pre-load- thus making the rear even more responsive
--Stronger than stock--will resist extreme abuse-- if binding should occur they are much more suited to resisting the loads applied to them, and will therefore last longer and be much more reliable.
--Bushings-- allow for slightly less articulation than stock, meaning part for part they will react faster than stock, limiting the body roll. They also help to protect the hiem joint from debris, allowing a much longer life compared to similar products.
--All major parts are either chrome dipped or anodized-- ensuring resistance from corrosion for a long time.
***Think of endlinks like Struts(analogically speaking)-springs will lower the car and make it stiffer, improving handling (the main goal), but the stock struts are usually not upto the task, and will in time wear out faster and cause their own side effects (i.e poor rebound, unpredictable control in rough conditions), the struts therefore should be upgraded with an adequitly suited set to ensure maximum benefit is achieved. In the reverse situation; performance struts with stock springs will just make the stock springs perform at their maximum potential (ie no side effects).***
cliff notes: endlinks are a COMPLEMENTARY PRODUCT to swaybars NOT a replacement.
Since no front swaybar exists for the 07+altima, the endlinks are your only option to stiffen the front end.
