Silvia007 »
https://forums.nicoclub.com/silvia007-u255.html
Fri Jun 10, 2005 5:40 pm
You're theory is correct, but there is one thing missing. When a certain boost level is reached which is determined by the user on the head unit, the valve will open, but it just doesn't stay open, because if it stays open the whole time, you will lose boost, so it's got to rapidly open and close the wastegate controlling boost to a certain level with different rates that the wastegate open and closes. I think the biggest issue is setting up the head unite which I have no clue in doing which is why I went with a MBC, but if your unit is new, I doubt it's broken. I'm suspecting the settings are at fault but I never really got my buddys EBC to work the way a MBC does. Hmmm....
