Fenvy »
https://forums.nicoclub.com/fenvy-u13048.html
Thu Jun 09, 2005 11:13 am
by the way, how do I know if my boost solenoid works?
I don't fully understand this and this is pure speculation:
at idle and low rpm when not in boost, there is small amount negative vacuum, I guess driving by the intake manifold
at higher rpm and in boost, driven by turbo through the intercooler then into the intake manifold, the vacuum change into moderate mount of positive pressure
part of this positive pressure is connected to wastegate actuator, and when an excessive mount of pressure appears, the spring can no longer hold against the positive pressure and the arm forces the internal wastegate open and dump the pressure
now, when there is a boost controller, it uses a solenoid that interrupts this process by stopping the positive pressure that drives wastegate actuator, and when a desired amount of pressure is detected, then it opens the valve in solenoid unit to let the positive pressure follow through and shove the wastegate wide open. Thus achieving higher boost
So in theory, the valves in the solenoid unit should SHUT by default until a preset amount of pressure is detected. I unplug the wastegate side of the actuator and felt the small amount of vaccum while the car is idling. I then unplug the entire unit and I can blow air THROUGH the solenoid unit with my mouth. Does that mean my solenoid unit is broken?
nevrmind my engrishhhhhhhh, I am just typing what comes into my head, which is a bunch of run-on incoherent gibberish I suppose
