R50 Tail Lights
Chrisbalkissoon
Will tail lights from pathfinders from the year 2000-2004 work or even the qx4 I have a 97 pathfinder and I'm not really liking the yellow amber section on my tail light just wanted to know if the Newer model r50's or qx4's tail lights would work by the way beyond that question I got another question on a cold start of my pathfinder it starts but when it does it struggles to start it starts for like 2 seconds then shuts off and then after I start it back up again she fires right up and gives me no problems but I just wanted to know what could be causing it to delay and just have a rough start hopefully someone can help me out
EdBwoy
For the qx4, remember the reverse lights are in the hatch, unlike the pathy, integrated in the tail light housing itself.
Otherwise, I went to the search bar at the top of the forum and typed in, "swap taillight" then "swap tail light" and I found this thread that says it's either easy or just needs a little modification:
1997-pathfinder-tail-light-swap-t514080.html
Side note:
For your other issue, I'd usually recommend you don't combine issues into one post as that makes it harder for someone browsing titles to find it and help.
I don't have an answer for it ATM, but I've seen quite a few threads on hesitation come up recently, maybe reading through one of those might give you some insight. Good thing yours is still driveable, right?
fueler
Car: 2 Nissan's
2 BMW's
EdBwoy wrote:
Fri Oct 06, 2017 9:18 am
97-00 qx4 have red & white tails with reverse.... 01-03 do not have reverse
