tmorgan22707 »
https://forums.nicoclub.com/tmorgan22707-u198679.html
Tue Feb 14, 2012 11:16 am
Super easy job. I have a 98 Pathfinder and noticed one of my tail lights was broken. I hate the yellow turn signals and nobody makes a nice aftermarket pair. I have read these forums and thought I would have to change the harness and bulbs and whatnot. I bought a pair of new 2000 Pathfinder tail lights online for 90 bucks. Install was a breeze!! The lights came with the harness and all I had to do was plug them in! I did install LED bulbs in the turn and backup spots. But had to do no modifications whatsoever. Plug and play. They look sooo much better than the factory lights too. Juts make sure you buy the lights with the harness attached and you should have no problems. Also if you are going to use LED turn signal bulbs you will need to replace the stock flasher with an LED flasher and take some of the dash apart to switch it.
