WDRacing wrote:You guys are throwing around alot of BAD opinions that are at best unproven.
12:1 on boost and a daily driver safe?...No. In the 12:1 range you're going to need a subinjection like methonal or higher octane base fuel then I can get which is 91. If you are running in the 12:1 range and removing timing to compensate...then you're losing more power then you're making by leaning the fuel map out. 11.5 is the leanest I'd tune anyones car who is concerned with daily driving safety. Especially when you're dealing with a lack of timing control. When I used 10:1 AF ratio in one of the above posts it was purely an example. The point was that it WILL burn colder and everyone's results WILL be different.
WD
I know you're a mod on this forum and all, but please allow me to step in here and oppose your statements.
I ran 13:1 on my daily driver, 6psi for 6mos. (190whp, 200wtq, NON-INTERCOOLED, TD04H-13C very small turbo, 93 pump gas) Then, went up to 10psi, 12.5:1, intercooled (not dyno'd) for another 6mos. No ill effects. Hey, guess what...I retarded timing to compensate and still made good power. In fact, I was able to pretty much match what the compressor map said would be available...with a 370cc/Walbro255/SAFC/stock MAF setup.
It's a scientific FACT that optimum power is made at ratios between 12:1 and 13:1 for gasoline powered combustion engines running 91-93 octane fuel. YOU CAN NOT BURN ALL OF THE FUEL IN THE CYLINDER WHEN RUNNING A 10:1 AFR. YES, it will be a cooler cylinder temp, but it's a waste of fuel. You'll receive safer, more efficient power outputs from running a proper AFR and retarding timing to correct for knock.
Why don't you take a look at the fuel curves on some Enthalpy or JWT tunes. You'll find them near 12:1 with timing maps to accomodate engine load.
Water injection works, yes. But it is NOT a substitute for proper tuning, as you keep insisting it is. Again, there are more variables when using water injection than can be accomodated for. ANY professional tune technician will tell you that throwing water and fuel at a timing problem is a horrible solution to the problem. In fact, it shouldn't even be called a solution.
So you saw some old Dodges running good times on primitive setups. Hooray. This doesn't mean that primitive is better. Scientific advancements aren't made to show that old, inaccurate, cumbersome technology is superior, but rather to put that old stuff to rest.
Not trying to be rude, but while your tuning methods keep your engine from blowing up, it's not anything that should be labeled as a good example.
Furthermore, you're trying to sell this guy a water injection kit (what, $150 maybe?) when he can buy a fully tunable BikiRom for the cost of an SAFC2, which is $250! That's beautiful.
Modified by KATwo40 at 2:49 PM 1/25/2006
